10-18-2017, 11:56 AM
Tow vehicle questions
We are asking any and all 5th wheel people about the best tow vehicle for the 5th wheel of my choice. We are wanting to purchase a Flagstaff Super Lite 526RLWS that has an empty weight of 7550# and a pin weight of 1410#. We are looking at a few pick-up trucks to tow with and need some advice. We will be 6 months parked in Florida and then travelling for 6 months between Florida to Virginia and back for the other 6 months.
We are looking at 1-Silverado LTZ 1500 with max tow package, 5.3L V8, 3.73 diff. with tow capacity of 11,100#.
2-Ram Laramie 1500 with 5.7L V8, 3.92 diff. with tow capacity of 10,300#.
We have also considered 2500 series in each make but the costs might not work for us and we were hoping someone would be able to tell us if the 1500's would work for us. We are not fans of the diesel engines because of cost, DEF fluid and previous experience with them.
We look forward to all constructive assistance in our quest to go permanent 5th wheelers.
10-18-2017, 12:12 PM
Your question will start a huge discussion . I have towed with both 1/2 and 3/4 ton. Fivers were 25', 29', 31', and 35'. Dry weights went from 7000 to 10k. If I had to do it over again, I would of started with a 3/4 ton. Period. Even for the 7k. The half ton will always struggle and be at it's upper capacity range. The 3/4 ton will give you a much more pleasurable traveling experience.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
10-18-2017, 12:24 PM
What are the payload capacities on those trucks?
WERA #13
'17 Work and Play 25WB
'11 F350 DRW
10-18-2017, 12:37 PM
T11ravis, The payload for the Silverado is about 2240 and the Ram is about 1800 I believe. I am not really very confident in the Ram numbers as they are close to max and the Silverado seems to have enough room to work with.
10-18-2017, 12:39 PM
Payload are the numbers to consider. My Ram Express 1500 with payload of 1780# comes out 400# over the rear axle GVW spec pulling my 7500# 5th wheel with a dry pin weight of 1380#. I did upgrade to LT rated tires and added airbags to the coil springs.
Made the trip to Alaska and back in 2016 with no problems.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
10-18-2017, 12:45 PM
So add in the cost of 'upgrades' to the half ton to assist the towing, but still be at the max capacities. Bet you will be right at the 3/4 ton price, which you don't have to modify. To me it's a no-brainer.
10-18-2017, 01:16 PM
I'm by no means part of what is called the "weight police" here on the forums, but neither of those trucks will handle the weight of that rig. Neither of them will have anywhere near that payload rating you're looking at unless they are bare bones models with zero options. The only half ton that I'd consider towing that fifth wheel with is the Ford F150 with the Heavy Duty Payload option. I'd highly recommend the 3.5L Ecoboost engine as well. It'll get MUCH better mileage than any 3/4 ton gasser( and it pulls much better to boot) and you avoid the complex emissions systems and much higher repair costs when out of warranty that today's diesels have.
Edit: Just noticed you are looking at an LTZ and a Laramie. Are you looking at the actual payload posted on the door or the brochure weight? I've never seen a 1500 GM or Ram with payload numbers even remotely close to what you are posting.
10-18-2017, 01:21 PM
2240# on the Chebby? Where are you getting that number? Maybe a stripper, reg cab, long box 2wd. The 1800# on the Ram sounds decent for a middle line truck.
I had a 5.3 2003 Silverado. Towed a 3000lb boat or a couple snowmobiles without issue. A big camper?, it'll suck (and not just the fuel).
My 2500 CTD is 2375#. DEF is cheap, I use 2 or 3 gallons in a summer, NBD. For me, zero maintenace other than oil and filters.
1400# pin weight is, in my opinion, at the high max end for 1/2ton towable. It'll tow it no doubt. Safely? margin for error while driving?
White knuckle in a 1/2, pass. Leisurely drive in a 3/4, yes please.
2013 Heritage Glen 272BH
2013 Ram 2500 CTD
1978 Corvette L82
3/4 and be done
10-18-2017, 01:35 PM
Think about the future, will you upgrade to a larger trailer in the future? buy a 3/4 ton now and don't worry about it.
2015 silverback 31IK
2023 f350
10-18-2017, 01:38 PM
A 3/4 ton 4x4 crew diesel in either of those trims he has listed will be at or over on payload, by the way. They'll have around 2K payload at the most- likely just shy of it. With a FW hitch and 2 people, even if he manages to keep the pin weight at the 1410 (will probably be closer to 1600ish when loaded, though). The F150 with HD payload will actually typically have a payload in the 2300-2400 range, and I'm talking actual payload, not a brochure rating. BTW, I just went to chevrolet.com and the MAX payload on a 2WD double cab is 2250 and that's a base model. I think 1700-1800 is most likely where it will be on the GM on an LTZ. The Ram I bet will be in the 1200-1300 range on a Laramie.
10-18-2017, 01:39 PM
As the others have posted check the CCC # on the drivers door frame ! Those #'s you posted do seem high !
1930 lbs CCC
2014 Jeep Rubicon JK
10-18-2017, 01:47 PM
I'll also add, FWIW:
I've gone from a 2011 F250 6.7PSD to a 2013 F150 3.5 Ecoboost to a 2015 F250 6.7 PSD and now back to a 2018 F150 3.5 Ecoboost. So I've had a little experience and compared both in MANY different towing situations and at varying loads. My personal stance is that I absolutely do NOT want a new diesel unless I absolutely NEED it. You'll notice that I've never gone the 3/4 gasser route. Much worse mileage and much less power compared to the 3.5 Ecoboost just never has appealed to me. I've also come to the conclusion that trying to purchase a truck for possible needs more than a year or two out has been futile as well. I'd never recommend getting anything other than what works best for right now unless you are reasonably certain you'll be upgrading your FW in the next couple of years. Obviously, others see it differently- this is just my .02.
10-18-2017, 01:48 PM
Who Dares, Wins
My Chevy 2500 ccc is 2500 lbs. My silverado LT had 1600 for some comparing some numbers. Both were short bed and 4x4.. So I agree do not use the web as the base, get the real numbers.
2015 Chevy HD D-Max
2022 Impression 315MB
10-18-2017, 02:10 PM
What cab configuration? My 2015 F250 SCrew 6.7PSD 4x4 XLT short bed with not a lot of options had around 2050 payload. Both are limited to a 10K GVWR- can't imagine a Chevy in the same configuration would be 500 pounds less.
10-18-2017, 02:16 PM
Insert witty title here
You can see my TV in my signature. It has a cargo capacity of 2490lbs. I've got crew cab with 6' 6" bed.
Get the diesel if you can afford it. Its' well worth it.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
10-18-2017, 03:10 PM
You've got pretty much exactly what I had except yours is an upper trim level. That means the Chevy is ~500+ pounds lighter than the Ford????
Edit: Maybe not- is yours 4WD or 2?
10-18-2017, 03:18 PM
Who Dares, Wins
Sorry thought I said, which I did not, both crew cabs.
2015 Chevy HD D-Max
10-18-2017, 03:20 PM
I'll skip the back and forth on this... You need an F450 diesel dually to tow anything from a yard trailer to a 40' fifth wheel. Hahahaha
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
10-18-2017, 03:21 PM
Who Dares, Wins
No you're still not good enough yet... Need a medium duty semi hauling a smart car to be sure you have enough truck!
2015 Chevy HD D-Max
