Old 06-11-2010, 11:10 PM   #31
I pull a Rockwood 8319ss with an Expedition 5.4 with tow package. Seems to do quite well, even in the mountains.
LAS8312 is offline   Reply With Quote
Old 07-05-2010, 08:58 AM   #32
I'm sort of in the same place as original poster.
Traded in a 25 ft surveyor and knew I was going to need a larger truck to two what I wanted... a 33 ft Jayco 33RLDS.
So I traded a 06 Silverado (7400 trailer cap) and bought a 2010 f150 with 3.73 rear end and the towing package. Also using Reese Dual cal sway.
The F150 is rated for 11200 pounds. My trailer is probably 8700 pounds loaded. The sway experienced is pretty unnerving especially on interstate. In Ford's defense, the Chevy dealer was also telling me that their new 1/2 ton Silverado would two this beast as well. Dealers are the LAST people that I will ever take towing advice from.
Power in the f150 with the 5.4 and 3.73 gear is good. I had the wrong gear in my Silverado previously and the difference is nothing short of miraculous.
I am in the process of getting some supersprings for the rear in the hopes of turning this thing into an f250. I am hoping for the same type of improvement. I'll let the post know how it goes.
sccamper is offline   Reply With Quote
Old 07-05-2010, 10:52 AM   #33
MtnGuy's Avatar
Before going to all of the trouble with the spring addition, check into the Reese Dual Cam setup to make sure it is done correctly. It is really important to make sure the cams fit in the crook of the trunnion bars, and also that you have enough weight put back on the front of the truck.
Check out: http://www.rv.net/forum/index.cfm/fu...d/17730894.cfm
The dealer did not have my WDH setup correctly, and I have numerous adjustments so that the weight is distributed "just right", and along with that several trips to a little used Lowe's parking lot access road so that I can do the straight line thing and then adjust the cams accordingly. I have my setup towing sweet now.
Old 07-10-2010, 11:44 PM   #34
Ric
I'm a first time user so have probably not entered this forum properly: I apologize in advance.
I have been reading the comments regarding the towing capabilities of the 2010 Ford F-150. I am considering the purchase of a 4x4 Supercab with the 5.4 L engine and 3.55 rear end. I am also looking into aquiring a 25 or 28 ft fifth wheel, both having a UVW of approximately 7950 lbs.
I think I understand the various opinions when it comes to towing a TT but my question is does the same criteria apply to a fifth wheel or do the towing dynamics differ? Bumper hitch vs truck bed connection. Does the FW sway as much on the freeways? Would beefed up suspension/air pacs be advised?
The dealer, of course, sees no problem with the F-150 but I thought I'd ask you folks after stumbling onto this site while researching the issue.
Any advise will be truly appreciated.
Ric is offline   Reply With Quote
Old 07-11-2010, 12:25 AM   #35
With that 5th wheel and truck combination, you won't be happy. The trailer will weigh 8500 when you get it home, and over 9000 packed and ready to camp. You will have about 1200 pound pin weight, and with that gearing I don't think your truck will like it. There are towing guides posted around here, just search for them.
I tow 7000 pounds with a 2001 SuperCrew 4x4, 3.73 gears, in the Smoky Mountains, and I do o.k., but that's all I want. Your main concern will be your rear axle weight limit. Suspension mods won't alter that.
As for a 5th wheel, they do sway some when you get passed by an 18 wheeler. Those that say they don't just don't care, or are trying to be loyal to their truck brand. I pulled one for several years, different truck. There is no sway control for them, and it is really is controllable. As with any trailer, care must be taken when towing. Also for a 5th wheel, it is recommended you have a long bed truck or a slider hitch. Sounds like you still have some home work to do. Good Luck.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 07-11-2010, 10:11 AM   #36
Well I have a 2008 Ford F150 Supercrew 4x4 with a 6.5 box and a 3.73 ratio rear end and a 5.4 engine and I tow a Puma 31BHSS with no problem!!!The towing capacity on my truck would be I think at 9400 and the 2010 truck has increased to 11,200 I think...
gucci is offline   Reply With Quote
Old 07-11-2010, 11:13 AM   #37
grhodes50's Avatar
If your 5'er's dry weight is 7900, you'll probalby be approx 8900-9100 loaded. So you'll be pushing your trucks towing capacity.
The problem that most ton owners run up against is the hitch weight. Say your loaded trailer weights 9000 lbs. With a TT your hitch weight (10-15% of loaded TT) would be 900-1350 lbs. The % of hitch weight depends on the TT. The same weight on a 5'er an your hitch weight (15-25% of loaded 5'er) would be 1350-2250 lbs, also the % of hitch weight depends on the 5'er.
Even if you go by the lower hitch weight, 1350, by the time you load up your truck with gas, people and gear you'll be at or over your GVWR. You can add air bags to level your truck, but they do not increase your GVWR. I guess if you add springs that would increase your GVWR. If it does, how much? I can't help you there, but I don't see how it could increase your RAWR.
RAWR, yeah another weight rating to watch out for. Also tons usually come with "P" rated tires. With that much hitch weight I highly recommend that you change to a load range "E" tire.
I see so many people focus in on the tow rating only, so I thought I might mention this info. Hope this helps.
Good luck and happy camping!
Gary & Trish
2018 Nights Camped - 5
Old 07-11-2010, 03:20 PM   #38
Just to put my two cents in, it seems that all of the TT I've pulled since I've been RVing (10 years and 3 different trailers) are within 300-500# of the GVWR of the trailer when ready to go camping. I have weighed all of them at a truck stop near our home and the first actual TT weight surprised me. After that one, I weighed all the rest because i felt the need to know what I was pulling and how the weight was resting on all of the axles. I think using the UVW gives you a false sense of security. Go weigh the rig and see for yourself. Cheap insurance.
RASwift is offline   Reply With Quote
Old 07-11-2010, 04:39 PM   #39
Ric
Thanks to all for the info.
I'm getting that uneasy gut feeling that I'm going to have to get a larger truck....I was hoping to avoid that in order to have decent fuel economy when using the F-150 for purposes other than towing a fifth wheel....which will probably be 75% of the time.
Back to the drawing-board.
Old 07-13-2010, 12:06 PM   #40
Ric,
If you upgrade and can afford about a 30% increase in a typical truck payment go with a diesel and at least a 2500. What a difference it makes. I had the 2010 F-150 with 5.4 / tow package/ 3:55 gears and with one pull I felt very uneasy. Granted I may have not gave my truck a chance and it has been a while since I towed anything, but I really felt like I did not have enough truck. I have a 2011 WRLS30. I traded for a 2009 Cummins 2500. Up the mountains of West Virginia with no issues. Down the mountains was even better with my tow/haul on and my exhaust brake on I hardly had to use my brakes. Yes my payment is more but the peace of mind I have with this rig now far outweighs the extra 170 bucks a month. Gas milage is very good when not towing and when towing it drops but not as much as it would with a gas motor. I get around 19 to 21 highway and 14 to 17 in town without towing. I got about 12 mpg towing overall. If you can then go with a diesel. Happy camping
Steve & Kathy
2010 4 nights
Gunnergm1 is offline   Reply With Quote
f150, flagstaff
