Old 05-17-2017, 03:03 PM   #1
Towing Info.
Good morning everyone,
We have ordered a new MicroLite 25KS and wanted to ask some questions on our tow vehicle. We have a new Ram 1500 Laramie Quad Cab, 5.7 Hemi, with 8 speed auto trans. and a 3.21 differential with anti-spin. Does everyone think that I'll be OK with this pick-up or should I look into changing the differential gearing? We didn't order it in the beginning because of the reduced fuel economy. Thanks for your replies.
navygrandparents is offline   Reply With Quote
Old 05-17-2017, 03:19 PM   #2
Scoundrel
HangDiver's Avatar
As I just learned recently (and others will chime in) your big limiting factor is the low payload capacity of the Ram 1,500. In fact, the loaded tongue weight of your Micro-Lite will take up 1/2 to 3/4 of your trucks payload capacity alone. And thats before you put passengers, gas, camping gear in your truck.
HangDiver is offline   Reply With Quote
Old 05-17-2017, 03:22 PM   #3
Steeljag's Avatar
Good morning,
Can you provide the CCC from your truck ? Sticker located on drivers door frame reading something to the effect of "weight of cargo and passengers should not exceed" # ?
Also then enclude the weight of the TT, and tongue weight ?
This will greatly help in you in getting the info you requested !
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 05-17-2017, 03:34 PM   #4
ram 1500
My Ram says max payload- 1480#, towing wt.-8010# and the MicroLite 25KS is- tongue wt. 544#, unloaded wt. 4713# and CCC 1433#. I hope this helps in answers
Old 05-17-2017, 03:58 PM   #5
saus's Avatar
Try this little calculator. It will give you an idea.
Towing Calculator based on Truck's Payload/CCC - Towing Planner
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
saus is offline   Reply With Quote
Old 05-17-2017, 04:13 PM   #6
aufinger's Avatar
Originally Posted by HangDiver View Post
.... your Micro-Lite will take up 1/2 to 3/4 of your trucks payload capacity alone. And thats before you put passengers, gas, camping gear in your truck.
Don't include gas against your cargo capacity. The truck's curb weight is the weight of a vehicle without any passengers or cargo, but including all necessary fuel, fluids and standard equipment. Larry G.
2016 Toyota Tundra 5.7L DC
2016 Flagstaff Micro Lite 23LB
USMC (Retired) 70-91
aufinger is offline   Reply With Quote
Old 05-17-2017, 04:20 PM   #7
True North's Avatar
My last Ram had the 3.21 axle and our trailer was slightly heavier than yours. With the tow/haul engaged for optimized transmission shifts and a blue ox wdh, we had absolutely no problems at all, regardless of terrain (i.e. Hills). It was never worrisome towing. In fact, the rig worked very well.
Terry, Sindee and Ranger
2017 Flagstaff 26rbws
2017 Ram CopperHead
Blue Ox SwayPro
True North is offline   Reply With Quote
Old 05-17-2017, 05:22 PM   #8
Scoundrel
HangDiver's Avatar
Thanks for setting straight my attempt to describe payload. I just gained another 180lbs payload capacity on my truck!
Old 05-17-2017, 05:29 PM   #9
You have 2 options-
1. Hook it up, realize that it's fine and enjoy camping.
2. Stress about it. Go weigh it. Weigh it again if you load differently. Want to take the kids/grandkids this time? Weigh them. Recalculate. Stress some more.
I think you get the gist and can gather what option I advocate you choose.
Old 05-17-2017, 11:45 PM   #10
You will be just fine. I'm pulling a Shamrock 23ikss hybrid with a 2013 Ram 1500 hemi. My hybrid is heavier with a higher tongue weight than your micro.
No problems with a E2 wdh.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
towing
