Old 12-31-2015, 01:04 PM   #11
Wayne Joan's Avatar
Originally Posted by robsshots View Post
What year truck are you talking about? The new F-150 ecoboost fords with the 3.73 rear end have a 12,000 lb tow capacity when properly outfitted. And you'll get in the high 20's mpg when not towing. I have a 2014 and tow a Rockwood fiver weighing 7800 dry weight. We towed over 7,000 miles last year, up mountains and down, 5%, 6% grades, no problem. I passed many a motorhome going up those mountains, maintaining 60 mph. Only white-knuckle time was coming out of Montana on an 8% grade downhill and I had warped rotors. Got those fixed under warranty and smooth sailing since. Get 10.5 mpg towing, 23 highway when not. Took a 300+ mile drive around Olympic Peninsula and got 24.3 mpg. 2016's do even better with 700 lbs of weight taken out of the truck. Just sayin'...speaking from experience...
X-2
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017
86 days camping 2018
Wayne Joan is offline   Reply With Quote
Old 12-31-2015, 01:11 PM   #12
frozen's Avatar
I towed a 9000 lb. trailer with a half-ton truck that weighed about 5200 lbs. It was okay, but I traded for a 2500 weighing about 7200 lbs. I hope never to need to tow with a light truck again. And spending a lot of time in mountains as I do, I surely don't want to be without an exhaust brake.
frozen is offline   Reply With Quote
Old 12-31-2015, 01:30 PM   #13
Go with the 3/4 ton diesel. You do not need the 4.10 rear end. I towed a similar 5r with f250 diesel 3.30 and 18 inch wheels and let the transmission do the hill climbing. Got 11-13 mpg towing and 19-21 unhooked. Consider tire/wheel size when making the rear axle selection. The torque curve on most diesels will put you at peak torque at 1600 rpm which on my tv was 65 mph --- my normal tow speed.
palmetto rogue is offline   Reply With Quote
Old 12-31-2015, 01:36 PM   #14
Towing with 1/2 Ton Trucks
I am using a Ram 1500 Quad cab to pull a 2005 FR 8283SS 5th wheel that fully loaded is within the maximum allowable for the truck. It works hard but does well. I am avoiding mountain trips but am comfortable in rolling countryside. If I had the $ I would move up but considering that 95% of the time, the truck acts as a car, I am happy with my 1/2 ton.
lheslop is offline   Reply With Quote
Old 12-31-2015, 05:03 PM   #15
LANShark42's Avatar
Unless you live in Florida and never plan to leave the state, why would you want to limit yourself by choosing a truck that isn't good towing in hills/mountains???
The fact that you CAN do something (I.E. "get by" with a 1/2 ton) doesn't always mean that you SHOULD! When I bought my camper, I did so knowing I'd need a truck big enough to COMFORTABLY tow anything I wanted, anywhere I wanted. I also knew that truck would not get gas mileage comparable to a car.
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
Old 12-31-2015, 05:07 PM   #16
davel1971's Avatar
This is my point in these conversations all the time. Funny thing is, the same ones who say they don't want to spend the money for a diesel truck, spend $10,000 more for a new 1/2 ton than I did for a new 1 ton diesel.
David & Lynn
Old 12-31-2015, 05:48 PM   #17
Lvn2tvl's Avatar
Originally Posted by davel1971 View Post
you will regret taking 2 steps backwards. Keep what you have
X2 totally agree. Since you already have the dually it kinda makes sense. I've seen allot of folks start with a 1/2 ton and when experience/RV size start to increase they move up. Not saying it always happens but it does happen. I started with a 4.6L Tundra moved to a 5.7L Tundra (really liked this truck), now have a 2500 HD Duramax 6.6L. Totally different pulling experience with the same 5er.
2018 Cedar Creek Silverback 29IK
16 Silverado 3500 HD 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 12-31-2015, 06:32 PM   #18
Canadian Contingent
Dogpatch's Avatar
Famous Last Words!
Famous last words!
1/2 Tons may be set up to tow a big load, but they ain't set up for stoppin it!
The only thing everyone talks about is payload and not what happens when you max a 1/2 Ton's GCWR out on an 8% downhill grade without an exhaust brake.
My Cummins exhaust brake will almost bring me to a dead stop on a decline. Without using my brakes.
You ain't doin that in a half ton! That I can guarantee you!
Les and Bonnie with 4 Leggers Bella and Shelby
2010 Cardinal 3450RL 4 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Pullrite 2900 Superglide 18k
Dogpatch is offline   Reply With Quote
Old 12-31-2015, 06:41 PM   #19
Kenny kustom's Avatar
Originally Posted by Dogpatch View Post
Famous last words!
X1.3 billion
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 12-31-2015, 06:46 PM   #20
Homebrew's Avatar
X2- also all the extras weigh more and reduce the payload.
When I had a 1500, the 20" tires reduced my towing by 1000 pounds.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
towing, truck
