Old 12-30-2015, 07:44 PM   #1
Towing with 1/2 ton trucks
I am new to this forum but I have seen a lot of people that are towing with 1/2 ton trucks? I have a 8528RLWS 5th wheel that has a weight 7200 dry and 9100 wet. This seems to be a lot for a 1/2 ton truck? Wright now I am using my F350 Ford diesel dull rear wheel to tow with. Use to have 4500 lbs of Lance Truck camper on the truck. I guess what am asking do these light weight trucks do the job? Would think a 3/4 ton with 410 axle and large Gas motor would be required or a diesel ?
porkchopjack is offline   Reply With Quote
Old 12-30-2015, 07:49 PM   #2
Kenny kustom's Avatar
Keep the dually?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 12-30-2015, 07:57 PM   #3
If you are set on getting rid of the Dually, at least go to a gas 2500/250. They are comfortable to drive with and without a trailer. Why try pushing the envelope with a 1500/150?
Bruce
Old 12-30-2015, 08:35 PM   #4
davel1971's Avatar
you will regret taking 2 steps backwards. Keep what you have
David & Lynn
Old 12-30-2015, 09:02 PM   #5
Ambassador
Ken K.'s Avatar
So you have a big truck, and you have small truck envy?
Don't be this guy...
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 12-30-2015, 09:06 PM   #6
Ambassador
Ken K.'s Avatar
OK so I took it to an extreme, sorry. I think if you can manage the payload with a 1/2 ton truck and make the numbers work, I say why not. With that engine, and that weight you may be limited to flat land towing...
Old 12-31-2015, 12:40 PM   #7
Dr Travel
What year truck are you talking about? The new F-150 ecoboost fords with the 3.73 rear end have a 12,000 lb tow capacity when properly outfitted. And you'll get in the high 20's mpg when not towing. I have a 2014 and tow a Rockwood fiver weighing 7800 dry weight. We towed over 7,000 miles last year, up mountains and down, 5%, 6% grades, no problem. I passed many a motorhome going up those mountains, maintaining 60 mph. Only white-knuckle time was coming out of Montana on an 8% grade downhill and I had warped rotors. Got those fixed under warranty and smooth sailing since. Get 10.5 mpg towing, 23 highway when not. Took a 300+ mile drive around Olympic Peninsula and got 24.3 mpg. 2016's do even better with 700 lbs of weight taken out of the truck. Just sayin'...speaking from experience...
robsshots is offline   Reply With Quote
Old 12-31-2015, 01:14 PM   #8
Capt. Mike's Avatar
Despite what your salesman and my friends with Ford Ecoboost say, you will feel far more comfortable with a 3/4 ton truck towing that unit. We had a 2011 1500 Silverado that did just fine towing our 26' travel trailer, but when we traded for our Windjammer (34' overall), we realized after the first trip that we needed to upgrade the truck. The half-ton pulled the trailer just fine on flat ground (as the salesman said it would), but going up and down hills (our first trip took us over I-40 through Asheville), the truck struggled going up and felt like it was being pushed coming down. Get the larger truck...you won't regret it.
Happy New Year.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 12-31-2015, 01:34 PM   #9
I'd be concerned about the payload capacity. Payload = total of loaded pin weight, fuel, passengers, pets, tools, firewood, bikes, canoes, kayaks, hitch weight, coolers, generator, etc.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 12-31-2015, 01:53 PM   #10
GSlone
1500
I will agree with all here. I do have a 1/2 ton and yes it will pull the trailer just fine but a 3/4 ton gas is the perfect combination. I'm looking to upgrade to the Chev. 2500 at some point.
Gary & Kelly
2016 Chev. 2500 HD
2014 Cherokee Wolf Pac 28WP
2009 Harley Davidson Street Glide
GSlone is offline   Reply With Quote
Old 12-31-2015, 02:04 PM   #11
Wayne Joan's Avatar
X-2
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017
98 days camping 2018
94 days camping 2019
Wayne Joan is offline   Reply With Quote
Old 12-31-2015, 02:11 PM   #12
frozen's Avatar
I towed a 9000 lb. trailer with a half-ton truck that weighed about 5200 lbs. It was okay, but I traded for a 2500 weighing about 7200 lbs. I hope never to need to tow with a light truck again. And spending a lot of time in mountains as I do, I surely don't want to be without an exhaust brake.
frozen is offline   Reply With Quote
Old 12-31-2015, 02:30 PM   #13
Go with the 3/4 ton diesel. You do not need the 4.10 rear end. I towed a similar 5r with f250 diesel 3.30 and 18 inch wheels and let the transmission do the hill climbing. Got 11-13 mpg towing and 19-21 unhooked. Consider tire/wheel size when making the rear axle selection. The torque curve on most diesels will put you at peak torque at 1600 rpm which on my tv was 65 mph --- my normal tow speed.
palmetto rogue is offline   Reply With Quote
Old 12-31-2015, 02:36 PM   #14
Towing with 1/2 Ton Trucks
I am using a Ram 1500 Quad cab to pull a 2005 FR 8283SS 5th wheel that fully loaded is within the maximum allowable for the truck. It works hard but does well. I am avoiding mountain trips but am comfortable in rolling countryside. If I had the $ I would move up but considering that 95% of the time, the truck acts as a car, I am happy with my 1/2 ton.
lheslop is offline   Reply With Quote
Old 12-31-2015, 06:03 PM   #15
LANShark42's Avatar
Unless you live in Florida and never plan to leave the state, why would you want to limit yourself by choosing a truck that isn't good towing in hills/mountains???
The fact that you CAN do something (I.E. "get by" with a 1/2 ton) doesn't always mean that you SHOULD! When I bought my camper, I did so knowing I'd need a truck big enough to COMFORTABLY tow anything I wanted, anywhere I wanted. I also knew that truck would not get gas mileage comparable to a car.
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
Old 12-31-2015, 06:07 PM   #16
davel1971's Avatar
This is my point in these conversations all the time. Funny thing is, the same ones who say they don't want to spend the money for a diesel truck, spend $10,000 more for a new 1/2 ton than I did for a new 1 ton diesel.
David & Lynn
Old 12-31-2015, 06:48 PM   #17
X2 totally agree. Since you already have the dually it kinda makes sense. I've seen allot of folks start with a 1/2 ton and when experience/RV size start to increase they move up. Not saying it always happens but it does happen. I started with a 4.6L Tundra moved to a 5.7L Tundra (really liked this truck), now have a 2500 HD Duramax 6.6L. Totally different pulling experience with the same 5er.
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 12-31-2015, 07:32 PM   #18
Canadian Contingent
Dogpatch's Avatar
Famous Last Words!
Famous last words!
1/2 Tons may be set up to tow a big load, but they ain't set up for stoppin it!
The only thing everyone talks about is payload and not what happens when you max a 1/2 Ton's GCWR out on an 8% downhill grade without an exhaust brake.
My Cummins exhaust brake will almost bring me to a dead stop on a decline. Without using my brakes.
You ain't doin that in a half ton! That I can guarantee you!
Les and Bonnie with 4 Leggers Bella and Shelby
2011 Cedar Creek Touring Edition 36RE 3 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Anderson Ultimate Hitch
Dogpatch is offline   Reply With Quote
Old 12-31-2015, 07:41 PM   #19
Originally Posted by Dogpatch View Post
Famous last words!
X1.3 billion
2016 Sabre 36QBOK
Old 12-31-2015, 07:46 PM   #20
Homebrew's Avatar
X2- also all the extras weigh more and reduce the payload.
When I had a 1500, the 20" tires reduced my towing by 1000 pounds.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
towing, truck
