Old 08-17-2019, 08:07 AM   #1
Travel with murphy bed down?
I have a microlite 21ds. Is it okay to travel with the murphy bed down?
Joemeyer905 is offline   Reply With Quote
Old 08-17-2019, 08:38 AM   #2
It's OK if you can do it.
Looking at your floor plan, I'd say your slideout will be in the way. It's in the way on my Mini Lite 2503S.
2011 Traverse LT, 3.6L, FWD
Old 08-17-2019, 08:39 AM   #3
If you can have the MB down with the slide-out in, of course you can travel with it down, ... there is no harm IF you can do that, ... but in most cases, when our slide-outs are in, we can not let the MB down, ...
fella10 is offline   Reply With Quote
Old 08-17-2019, 09:23 AM   #4
ours down almost all the time since our 2nd or 3rd trip. occasionally fold it up if company. found to be a hassle . slide not affected
gbaldwin is offline   Reply With Quote
Old 08-17-2019, 10:52 AM   #5
Thanks for the feedback. I was thinking that in the down position might help with tongue weight and gas mileage. I tow with a 1500 ram. The slide should just barely clear the murphy bed by about an inch or so.
Old 08-17-2019, 11:44 AM   #6
mpouls1's Avatar
The only concern I'd have is the legs scratching the floor. I've looked at mine and I'm sure they would scuff the floor from any jarring and movement.
2019 Flagstaff Microlite 25LB
2021 Silverado 3500 HD CCLB
2018 Escalade ESV
2009 CTS-V
mpouls1 is offline   Reply With Quote
Old 08-17-2019, 12:03 PM   #7
Im not thinking a difference on TW or MPG. Still weight and with mine its all still all distributed in the same position.... Forward of the axel. We leave it down to keep from having to remake the bed every night.
Old 08-17-2019, 12:22 PM   #8
that should be an easy fix, ... a rug, ... maybe small squares of carpet under each leg, ... or even attach, staple/glue, a pad of some sort to each foot, ...
Old 08-17-2019, 01:27 PM   #9
Traveled with the bed up and traveled with it down. It doesn't seem to make much difference. Even screwed up one time and traveled with the bed up but I forgot to strap the mattress in place... If you get a chance to do that, pass. It's not fun to wrestle with the mattress and topper with the bed half up and half down.
2007 Dodge Ram 1500 Hemi
2017 Flagstaff 21ds
WTP2 is offline   Reply With Quote
bed, travel
