08-01-2017, 06:48 PM
Tripping breaker
We have a 2017 25BHS, the 30 amp post breaker keeps tripping, it has happened at three different parks, not running the microwave when the air
Is on the only external thing on is a fan in the screen house is this normal? We've got about 45
Days left on the warranty.. any ideas? Also the cord is warm
08-01-2017, 06:53 PM
NOT normal!!!
I have never tripped the breaker at the post with over 30 years of motorhomes and trailers.
Don' know you unit, does it have two ac's?
Mark B.
2021 GMC 1500
Anderson WDH
08-01-2017, 06:55 PM
Fridge on AC, Water Heater on AC and the Air Con will make the cable warm! I think you need to investigate things a little more.
08-01-2017, 07:01 PM
X2 and don't forget the Converter can draw a few amps easily.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
08-01-2017, 07:04 PM
Tripping breaker
An amp draw per appliance would help determine your amperage issues. No EMS?
You can check amp draws by appliance with an amp meter. Cheap enough if you have the knowledge.
We lost power at a CG for a day over the 4th weekend. We used minimal battery we could and when the power came back on I think the converter was pulling 11 amps(by EMS). I was very surprised. If you aren't hooked up the entire time or have large D/C amp draw for some reason(i.e. trailer brakes or some other large draw) then this may be your problem. Our old unit had 30 amp, one a/c, 2 micros(not ran together) and the normal stuff with no problems. Maybe your converter is over working.
Assuming you don't have extra 120v stuff plugged up...i.e. freezer, ice maker, Grizwald type outdoor lights, or other crap I cannot think of then something is wrong. Maybe bad connection at the converter/a/c power cord connections? Maybe a very dirty a/c coil? I dunno. You might have to isolate the amperages to ever figure it out.
2017 Puma 297RLSS
08-01-2017, 07:08 PM
Since this unit is still under warranty, RUN back to the dealer and make them plug it in.
Turn on the ac, boil water in the microwave, put the hot water heater on electric only, and anything else you can think.
When it trips their breaker, they need to fix it.
Mark B.
2021 GMC 1500
Anderson WDH
Originally Posted by markb5900
NOT normal!!!
No it has one 1500k unit it is 91 degrees here today, earlier today it tripped three times in one hr. Earlier this week it tripped the breaker at the park distribution box, shouldn't you be able to run microwave and ac at the same time?
08-01-2017, 07:11 PM
Yes you should!
The CG has a problem it sounds like.
Mark B.
2021 GMC 1500
Anderson WDH
08-01-2017, 07:30 PM
Yes you should!
IMO, I don't think you can say this with any certainty until you check a few things.
I can watch my EMS and I know with the microwave and ac on, (as well as the converter, and the 2 Refrigerators), will trip the breaker after a few minutes. If the Microwave or AC is off, no problem, my EMS shows about 21 amps in this condition.
As some have stated, the only way to know for sure is add up all the 120 vac current draw and if it is close to 30 amps or over, it would not be unusual to trip a 30 amp breaker at the power post. And again, don't forget the converter is always drawing some current too and it could be more than you might think..
MISSION COMPLETED!
08-01-2017, 07:37 PM
No you can not! Is your water heater on electric? please answer this question.
For the record
AC Running 15 K BTU 15 to 18 amps
Water Heater 11 amps
Microwave 5 to 8 amps
Converter 3 amps float mode
TV 2 amps
Add them up You have 42 amps! Please take away what you dont have. Remember most breakers are rated for 80 to maybe 90% load factor for the expensive ones. What is the voltage? With low voltage the current goes up therefore the breakers trips.
08-01-2017, 07:45 PM
The OP stated this is still under warranty.
There is NO REASON WHAT SO EVER that they should be popping a breaker with a brand new trailer, period!
Unless there is a wiring problem within the unit.
Mark B.
2021 GMC 1500
Anderson WDH
08-01-2017, 08:02 PM
My guess is that he has more running than he realizes. Someone needs to clamp on an accurate amp meter and check out the power draw.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
08-02-2017, 07:29 AM
For the record
TV 2 amps
I'm running the electric HW, the only other thing running was a fan in the screen house with a 25ft cord. Yesterday when the temperature outside was 91 the breaker tripped 3 times with no microwave running. It did the same thing at other campgrounds . We only have 14 days in this camper with the a/c running, no problems in fall/winter/spring. Thanks for all the responses, it can be frustrating when you are camping with problems, but I know that part of it (didn't expect it with a 2017)
08-02-2017, 07:37 AM
Not necessarily, depending on other draws, like your converter.
In the summertime down here in LA with my 15,000 unit, I usually have to turn the AC off if using the microwave....or it trips the 30 amp circuit breaker. I only run the water heater on propane during the summer, for this reason also.
These threads may help explain it all, and energy management
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
The water heaters electric element and 30 amp power supplies are explained in edit #2 of the first post here:
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
08-02-2017, 09:53 AM
If you read the info in the links wmtire gave,
here are the typical current draws:
Converter - 8 amps
Microwave - 13 amps
Refrigerator - 2.8 amps
Roof a/c 13.5 amps
Add those together and you have 37 amps, 7 more than what the breaker is rated at. If the Microwave, AC and Converter are the only things running it is still over 30 amps.
To the OP, read those links from wmtire, great info!
MISSION COMPLETED!
08-02-2017, 10:29 AM
Am I reading you correctly that you are running your electric water heater as well as the other things? If so this is what is causing it to trip when the heater turns itself on. I suggest you turn it off and use the propane function of the heater as needed, or at least only turn on the electric water heater when you are certain you are not using other appliances that have a heavy draw (this is what I do). You most likely have a dedicated breaker in the converter where you can easily switch it off.
Is it the 30 amp breaker in your converter that trips, or the one on the pedestal? If it the one in the converter it is possible that it is defective and tripping below 30 amps. You could check it with an amp meter, or just replace it.
Andersen hitch
08-02-2017, 11:49 AM
It's tripping outside
08-02-2017, 01:23 PM
Then if you've had multiple breakers trip you are almost certainly overloading the circuit. You need to reduce the load as detailed above.
Andersen hitch
08-02-2017, 02:01 PM
With the power off open the panel up and check all of the line voltage connections on both the hot and the neutral screws for any loose connections especially on the 30 amp breaker
08-02-2017, 02:06 PM
I would also either try a different 30 amp cord or open the cord caps up and check those connections also. When you said the cord was getting warm was it the entire cord or at one of the cord caps loose connections make for a very large draw
