Old 04-05-2016, 10:51 AM   #1
TV
We're looking to get a larger tv for our camper. Do we have to get a special kind or can we get any tv? Not sure if there a special ones for campers. Thanks
Ltynman is offline   Reply With Quote
Old 04-05-2016, 10:56 AM   #2
rmac04401's Avatar
Only if you want it to run off battery 12v. Then you would need to buy a 12v TV. You can buy regular tv but you will only be able to use on generator power or when plugged in.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 04-05-2016, 11:04 AM   #3
rsdata's Avatar
If your current TV is hooked to your audio system, then note how many and what type of connections you have on the back of your current TV and what cable is hooked to those ports. Make sure the TV you get has the same or similar connections, or you may find that you cannot re-connect the cables you currently have. Not all TV's have the same type or number of ports on the back.
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 04-05-2016, 11:33 AM   #4
Thanks. We only use it when we're plugged in at the camp site, so we should be fine.
Old 04-05-2016, 11:58 AM   #5
Take measurements, go to walmart or best buy and pick what looks best to you. Im partial to Samsung, but put a Visio in the bedroom last year when my nearlymnew Toshiba started doing funny things.
donniedu is offline   Reply With Quote
Old 04-05-2016, 02:04 PM   #6
Thanks! I'm partial to Samsung also. Picking one up at Best Buy on sale. You guys are the best! Thanks
Old 04-05-2016, 03:44 PM   #7
aufinger's Avatar
When I first saw the name FURRION on my TT’s TV I thought – now that’s a brand I never heard of. However, after a little research, I learned that standard TVs are not made for a lot of jarring and shaking and that there are specialty TVs that are made specifically to be able to withstand quite a bit of movement. I take it that’s why FR uses FURRION TVs in their TTs. I’m sure there are other brands as well that are made for mobile applications.
aufinger is offline   Reply With Quote
Old 04-05-2016, 03:53 PM   #8
We have a Samsung in our TT and it has held up well for these past couple of years. I also built in a Samsung Blu-ray player about a year ago and so far no problems with it either.
keith_h is offline   Reply With Quote
Old 04-05-2016, 04:11 PM   #9
rmac04401's Avatar
Originally Posted by aufinger View Post
When I first saw the name FURRION on my TTs TV I thought now thats a brand I never heard of. However, after a little research, I learned that standard TVs are not made for a lot of jarring and shaking and that there are specialty TVs that are made specifically to be able to withstand quite a bit of movement. I take it thats why FR uses FURRION TVs in their TTs. Im sure there are other brands as well that are made for mobile applications.
Fur ion and Lippert are in cahoots together and have a major market share in the industry. I do not think they are better. Just a major sole supplier for FR. Just my opinion.
2005 Honda VTX 1300
