Old 06-12-2016, 09:11 AM   #1
OswegoLion's Avatar
TV Antenna
On my way to Ohio from New York. Great trip and little hiccup. I can get antenna to go up and down but I can't turn it. Right now it is down and end of it hangs over side. When I try to turn disc it won't turn seems to locked.
OswegoLion is offline   Reply With Quote
Old 06-12-2016, 09:21 AM   #2
bubbles's Avatar
You need to rotate the antenna to the stowed position with it raised. Then crank it down.
Old 06-12-2016, 05:47 PM   #3
OswegoLion's Avatar
A quick question. Where is stowed position? Sorry!!!
Old 06-12-2016, 05:57 PM   #4
SeaDog's Avatar
Look at the mounting above the hand crank. There will be a a pointed section pull down on the turning ring and match the point part on the turning ring to the point section on the mounting plate. That is the stow position for raising or lowering
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-12-2016, 07:27 PM   #5
Stank Bait's Avatar
Mine would not turn a few weeks ago when I was in WV. After much consternation I got out the instructions and found that it was supposed to be lubed. Who would have ever thunk that. Got the silicon spray out, climbed up on top and soaked the bugger. Removed the rubber plug, soaked some more in there and now it is slicker than goose grease. good luck.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 06-12-2016, 09:16 PM   #6
bubbles's Avatar
If this is what you have follow directions previously posted. See the pointed sections on the ring. Pull down on ring and rotate ring to align fixed pointed section and ring pointed section. This antenna is rotated to the right.
Old 06-13-2016, 10:36 AM   #7
To rotate the antenna...
1. It must be in the cranked up posititon. (not stowed)
2. You need to pull downward on the locking ring (spring loaded) at the ceiling to rotate. It will snap and lock into position when you release the ring.
To stow for travel, align the 'pointers' on the locking ring BEFORE cranking the antenna down against the roof.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 06-15-2016, 09:27 AM   #8
OswegoLion's Avatar
I can get antenna to up and down but when fully up I can't get it to rotate when I pull the ring down. It will not turn either way. Sounds like I may need to get on roof when we return from our trip Monday.
Old 06-15-2016, 09:34 AM   #9
Flybob's Avatar
When you pull the ring down, can you feel the locking mechanism disengage. I had the locking ring slip on one of my units and needed to be re-tightened.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-15-2016, 09:41 AM   #10
OswegoLion's Avatar
How do you re tighten ring?
Old 06-15-2016, 09:42 AM   #11
jeff64's Avatar
If this is the standard Winegard Sensar antenna...I've had the crank handle come off a couple times too. It does make a difference how far the handle is up on the hex shaft. If too far up you won't be able to pull the ring down far enough to clear the detents and be able to rotate the antenna. The set screw into that plastic handle needs a gentle touch in tightening or the threads will strip out. The setscrew is probably contacting in the last 1/4" of the shaft
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-15-2016, 09:43 AM   #12
OswegoLion's Avatar
Also it doesn't disengage.
Old 06-22-2016, 11:34 AM   #13
OswegoLion's Avatar
I tried your plan jeff64. I loosened set screw tried tightened a little still nothing. I even stated from scratch when handle and disk came off. Antenna goes up and down no problem but it cannot be turned with disc.
Old 06-22-2016, 04:47 PM   #14
Newbie
Sometimes when I rotate my TV antenna it gets hung up on my radio antenna. Have you physically looked at your antenna on the roof to see what's going on?
How 'bout them Cowboys!
2015 Rockwood 2104S
2013 F150 4x4 EcoPuller
okiecowboy is offline   Reply With Quote
Old 06-22-2016, 08:17 PM   #15
Stank Bait's Avatar
I am still saying, crawl up on the roof and spray/soak the bearing with some silicon.
Old 09-19-2016, 08:25 PM   #16
Yeah, mine needs lubed also. Anybody know where the jack is in a 2450. If you are headin to Houston avoid HWY 290. EITHER DIRECTION.
careyll is offline   Reply With Quote
antenna
