Old 06-11-2010, 05:47 PM   #1
52Dodgeman's Avatar
Two Gray water Only One Capacity Spec
Our 2008 831FKSS has two grey water tanks. Specs only give total spec of 60 gal. for grey water. Does anyone know if they are 30 gal. each or is the galley tank larger/smaller than the "grey water"?
52Dodgeman is offline   Reply With Quote
Old 06-11-2010, 09:17 PM   #2
rohlingerrv's Avatar
Is one called a galley tank? Ours has black,grey and a galley tank, the galley is sink water only..
rohlingerrv is offline   Reply With Quote
Old 06-11-2010, 09:40 PM   #3
Most likely they are the same size. Mine are. The galley tank serves the kitchen sink and the grey tank serves the bathroom sink and shower on my trailer.
Hokiehall is offline   Reply With Quote
Old 06-11-2010, 09:58 PM   #4
milzat's Avatar
I had the same floorplan in a Rockwood(8315SS). It is two separate tanks, both are 30 Gals each.
milzat is offline   Reply With Quote
Old 07-27-2010, 03:41 PM   #5
Are the two tanks connected or can they be connected?
bob7794 is offline   Reply With Quote
Old 07-27-2010, 04:22 PM   #6
The reason there are two gray tanks on some models is that the layout of the trailer prevents, or at least makes it very difficult, to plumb both the kitchen area and bath area into one tank. On mine, the kitchen is in the rear and the bath in the middle. It would be not be feasible to have only one tank due to the layout. Hence, you would not be able to connect the two gray tanks.
You can get a V connector to connect two hoses to a single connection at the campground sewer connection.
Old 07-27-2010, 04:30 PM   #7
Cyber Phrenologist
Radio's Avatar
We have found the galley tank fills up quicker than the others.
Another way to handle the "two tanks into one sewer" issue is to attach an adapter to the galley, run a green garden hose over to the fitting on a sewer elbow like this one.
Since I already carry an elbow and a green garden hose, all that adds to weight and space constraints is the galley-to-hose adapter, which is nothing.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 07-27-2010, 08:42 PM   #8
milzat's Avatar
No, they are not connected.
Yes, they can, but you'll need time and patience.
Galley & Grey water tanks re-plumb
flagstaff
