Old 12-13-2018, 10:00 PM   #1
Unhitching on an incline
Have a question about unhitching my 27' travel trailer on an incline. After backing and getting level, I go to raise and unhitch. Even though I have the wheel chocks placed, when the ball "pops" out of the hitch, there is a small lurch forward. Is this usual and will this cause problems? I'm thinking it can't be good on the front jack, seeing this is the only thing holding the trailer up. I've even pulled forward enough so there would be no "play". Still there is just enough lurch to make me nervous. Should I be? Understand I'm a 62 yr old rookie. lol
lbnt18 is offline   Reply With Quote
Old 12-13-2018, 10:09 PM   #2
Coach
Are you using regular chocks or X chocks? X chocks work pretty well in situations like yours. You could also try pulling the breakaway switch, but that would have to be left off until you rehook. If your anything like me you'd forget about putting that back together.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 12-13-2018, 10:17 PM   #3
Regular chocks. Thought about the X chocks, but haven't yet.
Old 12-14-2018, 08:45 AM   #4
Unless you have a way to wedge the regular chocks into the tires, on an incline. there is going to be some movement when unhitching.
Some folks will pull up slightly (or back up) on one chock before putting the second chock in and allowing the trailer to settle back between the two before unhitching, thus helping to wedge the tire to keep it from rolling.
X-Chocks help do this too since you crank them between the tires.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 12-14-2018, 09:03 AM   #5
Let me ask you guys this. How hard is it on the front jack. It on moves an inch or less. Just concerned it might damage it.
Old 12-14-2018, 09:36 AM   #6
I have many trailers. Utility, dump, flatbed, racecar, TT etc.
They ALL move slightly when unhooking.
The key elements are how much movement and how much weight is on the jack and also if the jack pad/foot slides or stays stationary.
Without knowing your variables, it is impossible for us to recommend whether your movement is acceptable. It does sound like your movement is minimal but again, we are not there.
Try the chocking procedure I recommended or get some X-chocks or something similar to help with the movement.
Old 12-14-2018, 09:52 AM   #7
Trailer moving when unhooking!
I have the X Chocks! They say right on them "Do not use when unhooking unit!" They won't interfere with regular chocks BUT you shouldn't use them until the trailer is level! Used more to really steady unit after disconnected and leveled.
tomm1947 is offline   Reply With Quote
Old 12-14-2018, 09:58 AM   #8
My tag trailer did that, jack slid a bit but didn't bother it. if it moves much and the jack doesn't slide, it might bind.
nayther is offline   Reply With Quote
Old 12-14-2018, 10:06 AM   #9
Manufacturers say a lot of stuff to CYA. (cover your a**)
My x-chocks are the first thing to go in and the last to come out.
I can slide the tires if trying to pull the trailer without removing.
They do a good job. Don't be afraid to use them.
Old 12-14-2018, 03:13 PM   #10
These are assumptions, so you know what that means.
You mentioned an inch or two of movement before the wheel chocks prevent additional movement.
Assumption 1: the tongue jack on your rig is adequate to withstand that small bending moment. Given your consistent parking in this location, it's not too expensive to upgrade the tongue jack to one rated for more weight...and more resistant to bending. I did this on my rig because I frequently setup lakeside on a sidehill, and the tongue jack must resist the natural twisting motion related to elevated to downhill tires and chocked uphill tires. There is always a little slop in the setup that torques the tongue jack a couple inches one way or the other.
Assumption 2: Your wheel chocks are "decent." In your case, junk wheel chocks might be the death of you. You need two premium ($30 per pair) wheel chocks for this service, and they need to have good "traction" with the pavement. You might look at solid rubber. (A pair of these will be $80) Steel X-Chocks are good, too, but these might do the trick, and nothing can break on these big lumps of rubber.
Assumption 3: You use a hammer or rubber mallet to drive the wheel chock under the tire as much as possible. A few gentle taps will improve initial engagement.
Assumption 4: After chocking the tires, you allow your trailer and TV to roll forward a bit to fully engage the wheel chocks to minimize "slop" in the system. You may discover that you must ease the tension on the hitch ball after doing this or the coupler will have a hard time releasing the hitch ball.
RELEASE THE LATCH on the coupler before backing the TV an inch so you don't push the trailer backwards.
Assumption 5: You are using a wheel dock and a drop leg - NOT A CASTER on the tongue jack. Casters have their place, but a caster is a very weak link in the chain in situations like this. Also, the long drop leg can be nestled far up in the tongue jack to further stiffen the jack tubing.
Assumption 6: IF YOU USE WOOD BLOCKING under the tongue jack, it should be extra long and stable...oriented up and down hill. A 6" x 6" or 8" x 8" block about 3 feet long will not roll or skid as easily as a small stack of 2" x 8" blocks. If you use wood blocking, it's better to not use a drop leg, because the jack pipe will bite into and grip the wood block.
Assumption 7: MOST IMPORTANT - your butt is not sandwiched between the trailer and TV when you disconnect. If you have an electric tongue jack, either get a wireless remote for it or fabricate a wired remote (paralleled with the main rocker switch) that allows you to stand clear as you lift the coupler off the ball. You can do this a hundred times without problems, but sooner or later, something might go wrong, and you don't need to get crushed.
Jim & Renee
2014 Forest River/Rockwood HW 277
Typical season is about 30 nights camping, usually nearby boondocking in the National Forests or at Lake Wellington
jimmoore13 is online now   Reply With Quote
hitch
