05-15-2012, 08:09 PM
#21
Brigitte
Also having trouble un-hitching. Thinking about grease but what kind to use?
Lube grease (black grease) or WD-40?
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
05-15-2012, 08:15 PM
#22
Had an old trucker friend that said use Vaseline, at least you can wash it off your hands and clothes. Used it for yrs. Doesn't make quite the mess and just about comes out of clothes.
05-15-2012, 08:17 PM
#23
Brigitte
The same vaseline we can also use on the wd bars.
Could using greese or vaseline be detrimental for hitching? Not like it's going to just slide out while driving right?
Superglide 2700
Timbrens
05-15-2012, 08:24 PM
#24
I used it on the ball, wd bars and the pivots on the 2 friction sway controls. If the wd bars are engaged, the trailer coupler will not come off the ball, BUT, it should be latched and locked/pinned.
If you have the Reese sway control bars with the crook in the ends, DO NOT grease them.
05-15-2012, 08:26 PM
#25
Brigitte
I tought (reese instructions) i could use vaseline on the reese bars where they sit in the cams to reduce noise.... :?
Superglide 2700
Timbrens
05-15-2012, 08:28 PM
#26
Equalizer recommends white lithium grease.
I used it on everything. Still use it on my Sliderite hitch rails.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-15-2012, 08:34 PM
#27
It will no doubt reduce the noise, but IMO it will also reduce the sway control somewhat. How much? Don't have a clue, but if it were me, I would put up with the noise when making slow turns.
You don't hear it a highway speeds where you need all the sway control you can get.
05-15-2012, 08:49 PM
#28
(Kim)
I have the same problem; I usually jump on the bumper while raising the jack.
I might try some Franks Red Hot sauce on it though, because I hear that you can put that sh!t on everything.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
05-15-2012, 09:20 PM
#29
Roy
Tow rig= 2009 dodge ram 1500 5.7 not built for towing ,, but a show winner.
2012 Catalina 27FBCK (Our first trailer!!!!)
05-15-2012, 09:22 PM
#30
Brigitte
Hot sauce ot is! How much do I need to consumme in order to jump on the bumper harder? Lol
Superglide 2700
Timbrens
05-15-2012, 09:23 PM
#31
Brigitte
Sounds fair, no vaseline for the bars. Noise not a big deal. Safety is!
Superglide 2700
Timbrens
05-17-2012, 09:31 PM
#32
I had the same problem , new trailer , hitch 4way equalizer .
I put new grease on the inside coupler and the ball
Another person suggested to stand on the bars
When I park I chock the wheels and snug the trailer forward . That puts the ball forward , raise the the trailer and step on the bars and the ball slips right out , the more you do it the easier. It will get
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
05-17-2012, 11:20 PM
#33
I have trunnion hitch with 2 way sway control and there is no way im putting lube on the bars. The design of the trunnion style is to limit sway with the metal on metal friction and lubing them will eliminate what the bars were made to do.
WD40 is a great CLEANER but not a long lasting lubricant (especially in the elements). White Lithium Grease is great though.
TT = 2021 ROO 233S
(Previous)TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2016 F-150 5.0L SCREW
Pit Crew: DW (Robin)
Kids: 9yo DD (Riley), 5yo DD (Kennedy)
Security: Boxer (Harley), yorkie (Willow)
05-18-2012, 07:12 AM
#34
If it's a Reese Dual Cam it's ok to use vaseline on the contact points, but the instructions say use a very light coating. I've been putting it on my Reese DC and it sure helps with the noise.
05-18-2012, 09:10 AM
#35
How much noise can it possibly make? Mine only makes noise on tight turns which is only a couple of times a trip.
TT = 2021 ROO 233S
05-18-2012, 10:00 AM
#36
The noise varies by setup. I had one trailer with an Equal-i-zer and barely any noise. Current trailer can get a bit noisy.
I just tell myself that other campers in the CG recognize the noise for what it is - a working WDH.
Although, I do have a piar of their Sway Bracket Jacket designed to quiet the ride. Haven't put them on, yet, though.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
05-18-2012, 11:52 AM
#37
Yes, only during turns and it can be quite loud sometimes, or seems loud anyway. I have to make 4 turns just to get out of my housing area.
05-18-2012, 08:54 PM
#38
I have these on my setup - it does reduce some of the noise but I found most of my noise was coming from the hitch head where the bars swing in and out (pivot point) - I put a dab of grease under there and reduced alot of the noise and still have no sway
I added a picture of where I grease the hitch head
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
05-18-2012, 09:52 PM
#39
Good points Sherdep. I grease mine there, too, and it helps. I've had the jackets for a year now and always intend to install before a trip but you now how it is. So many projects and so little time.
Scott
2012 Shamrock 233S
05-19-2012, 06:26 AM
#40
it takes less then a minute to install them - just slide from the bottom and they are on - those jackets will save the bottom of the bars too
I understand about the so many projects so little time - in the same boat
