Old 05-15-2012, 09:23 PM   #31
Brigitte
boubou's Avatar
Originally Posted by dunnnc
It will no doubt reduce the noise, but IMO it will also reduce the sway control somewhat. How much? Don't have a clue, but if it were me, I would put up with the noise when making slow turns.
You don't hear it a highway speeds where you need all the sway control you can get.
Sounds fair, no vaseline for the bars. Noise not a big deal. Safety is!
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 05-17-2012, 09:31 PM   #32
Capsfloyd's Avatar
I had the same problem , new trailer , hitch 4way equalizer .
I put new grease on the inside coupler and the ball
Another person suggested to stand on the bars
When I park I chock the wheels and snug the trailer forward . That puts the ball forward , raise the the trailer and step on the bars and the ball slips right out , the more you do it the easier. It will get
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 05-17-2012, 11:20 PM   #33
BlakeB's Avatar
I have trunnion hitch with 2 way sway control and there is no way im putting lube on the bars. The design of the trunnion style is to limit sway with the metal on metal friction and lubing them will eliminate what the bars were made to do.
WD40 is a great CLEANER but not a long lasting lubricant (especially in the elements). White Lithium Grease is great though.
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 05-18-2012, 07:12 AM   #34
If it's a Reese Dual Cam it's ok to use vaseline on the contact points, but the instructions say use a very light coating. I've been putting it on my Reese DC and it sure helps with the noise.
Len & Cheri is offline   Reply With Quote
Old 05-18-2012, 09:10 AM   #35
BlakeB's Avatar
How much noise can it possibly make? Mine only makes noise on tight turns which is only a couple of times a trip.
Old 05-18-2012, 10:00 AM   #36
Triguy's Avatar
The noise varies by setup. I had one trailer with an Equal-i-zer and barely any noise. Current trailer can get a bit noisy.
I just tell myself that other campers in the CG recognize the noise for what it is - a working WDH.
Although, I do have a piar of their Sway Bracket Jacket designed to quiet the ride. Haven't put them on, yet, though.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-18-2012, 11:52 AM   #37
Yes, only during turns and it can be quite loud sometimes, or seems loud anyway. I have to make 4 turns just to get out of my housing area.
Old 05-18-2012, 08:54 PM   #38
sherdep's Avatar
I have these on my setup - it does reduce some of the noise but I found most of my noise was coming from the hitch head where the bars swing in and out (pivot point) - I put a dab of grease under there and reduced alot of the noise and still have no sway
I added a picture of where I grease the hitch head
Name:	Grease area of Hitch Head.jpg
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-18-2012, 09:52 PM   #39
Triguy's Avatar
Good points Sherdep. I grease mine there, too, and it helps. I've had the jackets for a year now and always intend to install before a trip but you now how it is. So many projects and so little time.
Scott
2012 Shamrock 233S
Old 05-19-2012, 06:26 AM   #40
sherdep's Avatar
it takes less then a minute to install them - just slide from the bottom and they are on - those jackets will save the bottom of the bars too
I understand about the so many projects so little time - in the same boat
led pad
