Old 04-10-2019, 05:52 PM   #1
upgrading tv size
Checking to see if anyone has put a larger tv in there flagstaff. Ours has a 32" in the cabinet that swings out to allow access to the storage behind.I would like to put a 43" in,but not sure what bracket to use.
AWLINK is offline   Reply With Quote
Old 04-10-2019, 06:04 PM   #2
Witch Doctor's Avatar
Why won't that bracket work? If the hole pattern is correct, the weight is really not a issue. If it was recessed, you might have to add a wood spacer behind the bracket to make it clear the recess, I couldn't tell you that but the bracket should work. Your going from 32 to 43.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-10-2019, 06:15 PM   #3
x2. bracket should not be an issue. having enough room for the tv would be my only concern.
Kimber45 is offline   Reply With Quote
Old 04-10-2019, 06:26 PM   #4
The tv would be on the face of the cabinet instead of inside the opening like the 32 is. It would need to come out and swing around the outside of the cabinet instead of swinging to the inside like the 32 does.
Old 04-10-2019, 06:38 PM   #5
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
My rig had a 32” tv. Took forever to rescan channels and was just a crappy set all around. Bought a 43” 4K name-brand TV on sale for under 200 at Best Buy. Instead of inside the opening, it is outside. Looks surface mounted now. Was able to use the same bracket, but had to relocate it a bit so the TV was up higher. This one has all the bells and whistles, weighs just a bit less than the set I took out! Better picture, lightning fast for rescanning!
Only downside, draws just a few watts more than the old set. 300MA more. I say this, in case you boondock and run an inverter. It does draw a bit more power, but not really enough to worry about.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 04-10-2019, 07:27 PM   #6
bikendan's Avatar
It would be helpful if you posted year and model number, since you didn't list it in your profile. That way those that own the same model, can more helpful.
Some Flagstaff models may not have room for a bigger tv.
Just saying Flagstaff, isn't enough information.
Equalizer WDH
Old 04-10-2019, 08:05 PM   #7
Upgrading tv
I have a 2019 Flagstaff 26rbws
Old 07-22-2019, 07:43 PM   #8
Do you have any pictures? I'm looking at upgrading to a 40".
rmk184 is offline   Reply With Quote
Old 07-25-2019, 12:57 PM   #9
Any luck mounting a larger tv?
Old 07-25-2019, 06:30 PM   #10
Recently new!
Paulie1138's Avatar
Hopefully it will load this time.
2001 Ford F-250 7.3
