Old 01-02-2019, 11:07 AM   #1
dieseldodge's Avatar
Use a garbage disposal as a RV macerator?
Been looking at macerators for the RV. Discovered some use garbage disposals. Any one use such an arrangement? Any words of wisdom?
dieseldodge is offline   Reply With Quote
Old 01-02-2019, 11:08 AM   #2
Like you... I've read about it.
Never seen it but not sure I'd want to either!
Best of luck if you do and post your results.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 01-02-2019, 11:22 AM   #3
Denver To Yuma In 90 Days
A garbage disposal in the kitchen sink of an RV is probably not a good idea.
You most likely will have a real hard time trying to get that sludge out of the gray tanks.
2015 Heartland Prowler P292 5'ver
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear axle
"Just because someone has been "doing it for years with no problems" doesn't mean YOU should!"
JohnD10 is online now   Reply With Quote
Old 01-02-2019, 11:33 AM   #4
BessieHunter's Avatar
Macerators have a pump behind the grinder blades, garbage disposers do not. So you would have to have the discharge hose going down hill to the termination point, unlike the macerator that can pump uphill and long distances.
BessieHunter is offline   Reply With Quote
Old 01-02-2019, 11:50 AM   #5
They use the garbage disposal outside on the ground, similar to a 'normal' macerator. I even found a website that sells kits to turn a disposal into a 'macerator'. The video shows him 'pumping' 100 feet thru a garden hose and even holds the hose up seven feet with a steady flow.
Old 01-02-2019, 12:35 PM   #6
My house uses one, everything coming from the house is ground to a slurry and shot up a pipe the size of a garden hose 1/3 mile up the street to there the sewer pipe is as my house is well below the city sewer. Can't see why it wouldn't work for a camper other particles building up in the tank if not flushed enough.
2018 Rockwood 8244BS
2006 F250 6 speed
[SIGPIC]
kamper00 is offline   Reply With Quote
Old 01-02-2019, 12:59 PM   #7
Broken Toe
Cowracer's Avatar
Why not? They make great margarita machines!
ACME TEQUILA COMPANY Developers
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 01-02-2019, 01:44 PM   #8
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Note to self after several Margaritas....
DO NOT use mixer for double duty as the sewer discharge piping.....LOL!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14
2001 Ford F-250 7.3
A Loving wife and Mason the always dirty dog!
Paulie1138 is offline   Reply With Quote
Old 01-02-2019, 02:02 PM   #9
I will attempt to re-claim this thread by re-asking if any one has any experience with the original subject matter? Would appreciate any feedback before I give this a try.
Watching a few videos of 'regular' macerators (with the 12 volt motors) pumping long distances, it seems they struggle, and the reviews are underwhelming. It strikes me that a larger motor on 120 volts might work out better, though they (garbage disposals) weren't intended to do this....at least I didn't think so.
Old 01-02-2019, 02:23 PM   #10
110 volt macerator pump
Homemade macerator pump
2011 Traverse LT, 3.6L, FWD
