Old 03-23-2018, 03:04 PM   #1
want to add 2nd a/c
I have a 2011 flagstaff 831fkbss and I want to add a a/c in the bedroom where the roof vent is.anybody done this?
psb retired is offline   Reply With Quote
Old 03-23-2018, 03:10 PM   #2
are you prewired for it? do you have 50amp or 30 amp?
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 03-23-2018, 03:31 PM   #3
no pre wire
as far as I know there is no pre wire.30a service,i was planning on put a water tight outlet maybe on the shroud and use a 12gauge extension cord to plug it in,the unit I am looking at is rated at 10fla,i wa concerned about the roof
Old 03-23-2018, 03:35 PM   #4
llr
If they offer a 2nd AC the roof is probably ok as I doubt they would change the framing based on if it is getting the 2nd air or not, there is a fair chance you will even find the wires ran to it.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is online now   Reply With Quote
Old 03-23-2018, 03:42 PM   #5
fonzie's Avatar
Here is one thread....
Second a/c
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-23-2018, 04:14 PM   #6
not sure if a 2nd a\c was offerd in 2011,i see you have anewer model,did it offer a 2nd unit?
2011 flagstaff 831fkbss 2003 excursion 6.0 diesel bulletproofed
Old 03-23-2018, 04:15 PM   #7
thanks I will check it out
Old 03-25-2018, 01:33 PM   #8
adding a 2nd AC
I have a 2016 Primetime Crusader Lite that was not wired for a 2nd. AC, follows is the work around to adding one. The cutout for the sky light in our bedroom was the exact size that was called for the installation of AC unit. I did have to close off the front and rear side of the opening, but the structure of the roof was strong enough to support the weight of the unit. It supported my weight at 295 lbs. The unit I installed was a Dometic 15K non ducted with ceiling controls. 6 guage wiring was added by running from ceiling opening, across ceiling, down the outside wall, through the floor to a 20 amp circuit breaker, used a house type breaker and box. Wiring was then ran to a 30 amp plug, same as came with the trailer. Mounted this plug in skirting on bottom of trailer and brace with steel bracket underneath. I use a standard 30 amp rv electrical cable to plug in campground post. I have pictures of the installation if you would like to have. Send your request to "Walholler@hotmail.com". Remember, if there is a will, then there is a way.
Walholler is offline   Reply With Quote
Old 03-26-2018, 10:51 AM   #9
2nd a/c
thanks for the info I will e-mail you for the pictures
