Old 01-22-2017, 08:40 AM   #1
mikdor1's Avatar
Wardrobe slide Ques...
Curious how you put wardrobe slide in if something go's wrong with motor. Large slide has manual crank can't find motor for small slide. It's the 524rlws flagstaff.
2017 Flagstaff 524RLWS
2015 F150 , 5.0 , 3:55 axle
mikdor1 is offline   Reply With Quote
Old 01-22-2017, 10:02 AM   #2
Sounds like your wardrobe slide is a Schwintek. (gear rails mounted to outside of slide)
You have to disengage the drive motors to manually put the slide in. (or out)
Below is a video showing how to do it.
There are others if you search YouTube.
Your signature line indicates you have a 2017 unit.
Shame on your dealer for not either showing you this or explaining a little about the system and pointing you to information on how it is done.
As you have determined by asking this question, it is good to know how the many basic RV 101 systems work BEFORE finding you have a problem. Knowing what to do in advance (or where to look) is always good.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 01-22-2017, 10:34 AM   #3
mikdor1's Avatar
5picker, thanks for the info. The reason I joined is because of members like you. Valuable info before a problem, hopefully no problems.
slide
