Old 07-28-2014, 05:14 PM   #1
Chismo's Avatar
Water drain
Can anyone help me. I found a drain under our sofa. We recently bough a 2010 Flagstaff Micro Lite 25DS. Not sure why a drain is needed under the sofa
2009 Silverado Z71 4x4
Chismo is offline   Reply With Quote
Old 07-28-2014, 05:39 PM   #2
Ford Idaho's Avatar
Looks more like a fill hose or perhaps a flush.
What is outside?
Old 07-28-2014, 05:46 PM   #3
Chismo's Avatar
Just a drain hose under the trailer not going anywhere
Old 07-28-2014, 05:52 PM   #4
Ford Idaho's Avatar
Sorry, I meant what is outside on the wall right where that is?
The second IMG looks like an overflow tube because it is not capped.
Old 07-28-2014, 06:30 PM   #5
Chismo's Avatar
Nothing on the outside. This mounted under the sofa slideout. Here's another look.
Old 07-28-2014, 06:54 PM   #6
Plain Old Member
Never seen one before, but almost looks like a catch pan and drain for any water that may get past the seals? Is there one of those contraptions on the other end of the slide? Did you purchase this camper new? Reason I ask, is just curious if this was a quick fix for a leak.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-28-2014, 07:00 PM   #7
They are drains for any water that comes by slide seals. I have a 2014 Rockwood 2109s and it has them at both ends of the sofa on the slide.
bojangles is offline   Reply With Quote
Old 07-28-2014, 07:04 PM   #8
Chismo's Avatar
Thanks Bojangles. I thought it might be for possible slideout leaks. I just hope I never see any leaks!
Old 07-28-2014, 07:42 PM   #9
At least they'll drain properly.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 07-28-2014, 08:03 PM   #10
VinceU's Avatar
That's pretty scary if for slide seals, do you have toppers to prevent the seal leaks, not catch it? Seems like putting the cart before the horse.....
Old 07-28-2014, 08:22 PM   #11
Chismo's Avatar
I'm not sure what "toppers" are. Also I bought this used so I don't know if this was a factory fix or not. It does seem odd that FR would install a drip pan for a possible leak
Old 07-28-2014, 08:41 PM   #12
VinceU's Avatar
Sorry a "topper" is a small awning that opens with the slide and keeps rain etc off the slide top when open. Its got overhang on all sides to help keep water from the seals. On a 2nd look, the sealing outside does not look 4 years old. I'd ask the seller if known what that rig is for.
Old 07-28-2014, 08:47 PM   #13
Is it a 2nd Bathroom? Youroo!!
Old 07-28-2014, 09:05 PM   #14
VinceU's Avatar
No bathtub fitted, just a "trough". Missing blue tub outside.....
Old 07-28-2014, 09:06 PM   #15
I bought my trailer new in October of 2013 and those were in it when I bought it. I did have a slide topper installed before I picked up the new trailer. When you retract the slide if it is raining the seals wipe the side of the slide as it is retracted and those drains catch any water that drips off during that time and drains it outside instead of on your floor.
Old 07-28-2014, 09:17 PM   #16
Slympicins's Avatar
Interesting conversation. I will have to look at our TT to see if we haven them also.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Slympicins is offline   Reply With Quote
Old 07-28-2014, 09:53 PM   #17
jtstromsburg's Avatar
Our old Grey Wolf had them too. I never noticed any water going through them, but they were there. Wouldn't work on flush floor slides.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
drain, water
