Old 06-12-2018, 08:04 AM   #1
Water filter in Microlite
Flagstaff Microlite 21FBRS. The water filter that is installed in this trailer..does it filter both hose water AND fresh tank water?
2014 Flagstaff 21FBRS
2013 Toyota Tundra 5.7
Skeetzee is offline   Reply With Quote
Old 06-12-2018, 08:23 AM   #2
Yes. See attached generic plumbing pic at the bottom of this post.
You may want to consider removing it and using an external filter. If it's an FR1 , like in the pic below, there are many horror stories of them cracking and flooding trailers.
Name:   FR1 filter pic.jpg
It can be replaced with a 1/2 PVC coupler.
Name:	half inch DURA coupling.jpg
Here's mine:
Name:	Filter replacement coupling.jpg
If you remove it and use an external filter, it won't filter your FW tank water. However, if you use the filter when filling your FW tank, it will already be filtered.
2011 Traverse LT, 3.6L, FWD
Old 06-12-2018, 08:38 AM   #3
Perfect..thank you for the pic..I do also have a blue external filter on the hose. What would cause the FR1 filter to crack? I've been using mine for over 5 years and so far no problems with it. It's easy to change the filter and my water is filtered twice. It tastes delicious and I'm not contributing to the fake clean water phenomenon of bottled water. What a scam! But I will keep an eye on the FR1. Be a big bummer for that thing to break.
Old 06-12-2018, 09:12 AM   #4
I'm not sure of the cracking mechanism, but definitely many reports of it happening.
Old 06-12-2018, 01:36 PM   #5
Kasual Kamper
Originally Posted by Skeetzee View Post
What would cause the FR1 filter to crack? I've been using mine for over 5 years and so far no problems with it..
What have you been paying for cartridges? Pricey little suckers, aren't they?
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 06-12-2018, 06:30 PM   #6
I use the “blue” in hose filters from Walmart.
I like to filter the water before it flows into the TT.
rwatson908 is offline   Reply With Quote
Old 06-12-2018, 07:44 PM   #7
Villagerjjm's Avatar
I have heard reports of the housing cracking, but I have never seen any photos of one that has cracked. I have used this filter and housing for over 6 years without any problem what so ever!! The only complaint that I have is that the filter itself is so damned expensive, but the filter does perform spectacularly! I have looked at all the alternatives and I have decided to keep using this filter system. We set up on my daughter's property with full hook ups and tap into their well water. My daughter is very "anal" about her water quality. Of course, well water will produce a "Sulphur" smell that some find offensive. My daughter has her water tested every 4 months for EVERYTHING !!! Chemicals, bacteria, minerals... whatever... EVERYTHING!!! It costs her, but like I said, she wants clean water with no insecticides, round-up residues... whatever. It still has a Sulphur smell in her house... but not in the camper!!! The filter gets rid of that Sulphur smell entirely. When I am camped at her house, I also get my water tested. My test results come back a little better than hers. No sulphites, organics, bacteria or pesticides / glycophides. I think it is because of the KW1 filter system. I am going to keep mine. NOTHING CAN COMPARE WITH THE SPECS !!!
Villagerjjm is offline   Reply With Quote
Old 06-12-2018, 08:04 PM   #8
Lots of reports of leaks. But you're right, no photos that I've found. But they've leaked from the O-ring, and they've cracked. Put "filter leak" into the search field above and you'll get a lot of threads.
Not all well water smells of sulfur. Mine doesn't. I've been on it for 35 years. The sulfur smell seems to be more of a southern US issue, I think.
Old 06-12-2018, 08:37 PM   #9
Life Without Whine's Avatar
ours cracked at the teeth where it screws back together but we were initially unable to appreciate that problem; thought we had just jostled loose.... was a MESS to clean up - twice. Have changed out our unit now
Terri + Joe + BrewDog Boont
Camping a long weekend every month since starting in May of 2013 in order to practice for retirement .... Florida is a great state to have this bad habit
Life Without Whine is offline   Reply With Quote
lite, water, water filter
