Old 05-13-2018, 11:04 PM   #1
Water Filter Woes
I just about choked when I saw how much the Water filter is for my Flagstaff. Have a 2016 Flagstaff Classic Super Lite 832IKBS. Some how I got two filters when I picked the unit up. Camped one season, winterized and had that spare to use last year.
So honestly there is no way I am buying a 10 micron filter for that price, I cannot find any other filter that will fit the unit in the TT.
Wondering what others here have done.
Replaced the filter housing with another?
Used a external filter?
Submitted to highway robbery and just bought the replacement filter from Forest River?
Thanks,
SubVet is offline   Reply With Quote
Old 05-13-2018, 11:08 PM   #2
NMWildcat's Avatar
Thanks,
I take the internal filter and housing completely out of every rig of ours. We used to try external filters, but got tired of those and now don't use any filters. Much happier.
Scott and Liz - Southern NM
Old 05-14-2018, 02:27 AM   #3
Just as confused as you
Scrapper's Avatar
I have a 2014 Flagstaff Classic Super Lite 832IKBS and I bought a hose to replace the filter housing. Just unscrew the fittings from the filter and connect the hose to the plumbing. No need for hose clamps, it screws to the fittings. I use a whole house filter outside under the trailer. I'm not at the trailer til later this week so I can't get any pictures.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 05-14-2018, 05:12 AM   #4
cavie's Avatar
Remove the internal filter and housing. Install Camco inline filters to the supply hose outside. Throw away once a year.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-14-2018, 07:16 AM   #5
Kaadk's Avatar
Which filter do you have? The KW1 or the CCI-10? Our Flagstaff had the CCI-10 and I could get compatible filters from our dealer for only 10.95 (+HST). Yes, itís more than what people quote for their whole home filters on here, but itís not unreasonable. Works out like $2.00 a month for us. Certainly not enough of a difference to warrant replacing the filter canister.
Old 05-14-2018, 07:41 AM   #6
Filter cartridge prices Totally depend on "What you are trying to Filter Out"! A "String spun element for Sediment or a Multi stage charcoal/carbon filled" BIG price spread! Most people think the Element inserts are the same! We use a Outside Whole House unit then filter at other locations for water needs! Youroo!!
Old 05-14-2018, 07:52 AM   #7
jeff64's Avatar
X2
Removed filter like so many. Cut the white hose close to filter. Cut off band clamp with dremel/disc at the T. Peel off the PEX and reconnected white hose at T with new band clamp. Now use whole house filter with tase, odor sediment filter @ 2/$9
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-14-2018, 08:34 AM   #8
Yep, the FR1/KW1 filter elements are ridiculous expensive and propitiatory to the filter housing. There have been a few reports of someone installing an off-brand element in the FR1 but then others who say not.
I removed mine and installed a connector to splice the two lines back together and just use a good whole house filter at the hydrant or when filling the fresh tank. Good whole house filter assemblies can be had for the price of the KW1 element.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 05-14-2018, 08:43 AM   #9
Replaced mine
I replaced mine with a Pentek housing that takes standard cheap filters. Don't get one with a pressure release button as sometimes they weep. Pressure release is not necessary on a trailer just open a faucet.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
water, water filter
