Old 06-18-2014, 07:58 AM   #1
Water filters
We are new to the TT world and will have our maiden voyage this week. Moving up from the popup. Is it necessary to install the water filter if you wont be drinking the water? What happens if we don't? Will the chamber still fill? Will it bypass somehow? Also does anyone pour the blue chemicals down the other drains besides the toilet? A friend mentioned they do. Thanks!
PTLady is offline   Reply With Quote
Old 06-18-2014, 08:03 AM   #2
Use a filter regardless,they Help filter out (Junk-??) that will -can cause problems in your (Water system)! Youroo!! Filter= (Pay now or Pay later)!
Old 06-18-2014, 08:51 AM   #3
TURBS's Avatar
If your camper is "new" it most likely has a filter?
Why wouldn't you drink the water?
TURBS
"Sabre owners united"
Old 06-18-2014, 08:54 AM   #4
Kaadk's Avatar
x2.
We don't drink the water, we bring a case of bottled water for that. What the filter does is let me know I'm washing, showering and flushing with water that's at least been filtered somewhere and isn't coming straight out of a well.
I'd only ever consider skipping the filter if:
1) I only ever use the freshwater (FW) tank.
2) I only ever bring FW from home and never fill the tank elsewhere.
3) I fill my tank with water with filtered water.
And even then, I'd still probably use the onboard because hey, why not?
Old 06-18-2014, 08:58 AM   #5
Slympicins's Avatar
Water filters
Careful with your filter:
Originally Posted by Slympicins View Post
For those with the 27RLWS here is a real good reason to TURN OFF THE WATER when you leave.
I closed the compartment where the water heater and water filter is located. I walked over to my neighbors camper for less than 1 (one) minute to talk. My buddies wife came out of the camper next to ours and yelled, Guys we have a problem here!" The water filter housing backed it's way out and was dumping water inside the compartment. Got a little inside on the carpet to. The filter housing DOES NOT LOCK into place and slowly backed out. As a result, I deleted (removed) the entire water filter system and added a section of pipe where the top if the filter was. I didn't trust it not to do it again. It cost about $15.00 for the pipe and fittings but no more worries!!!!
I don know about your TT but I prefer the hose bib filter outside the TT.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 06-18-2014, 11:37 AM   #6
Thanks for all your replies. It did come with a filter but is not yet installed. Was wondering if we need to install it and if not, what will happen. Slimpicins we have a microlite 25ds. So do you all pour the blue stuff down the drains with water? All we have right now are the pouches you put in the toilet.
Old 06-18-2014, 11:39 AM   #7
Another question. We have a water regulator fitting. Does that attach to the hose by the water source or where you connect the hose by the TT? Thanks again.
Old 06-18-2014, 12:14 PM   #8
Kaadk's Avatar
1) I only use the TST in the toilet. But I've heard some people will occasionally use some in the grey tank. It seems to be a personal preference.
2) I put the water regulator at the tap. Others will put them at the trailer. Again, a personal preference.
3) If you don't install the water filter, the housing will fill up with water and will still function fine. However, there are debates about whether or not that will make it more prone to leaks, like Slympicins experienced. The one thing we all seem to agree on is to make sure the filter housing is tightened with the supplied wrench, but not overtightened. If it's too tight it cracks and then leaks. If it's too loose it can spin off and leak (a lot). If you're not going to use it anyways, then the best option is to just eliminate the entire housing and replace with a short piece of hose so you don't have to worry about leaks.
Old 06-18-2014, 12:20 PM   #9
I don't trust the filters any more than the water. Most people leave the filters in the camper for the entire season. It is just not convenient to remove them after each trip. Sitting in a warm, dark,wet environment for bacteria is just like putting them into an incubator to grow. No thanks. I removed my filter and use one of the Camco external filters to fill my tank. I drain my fresh water tank after every trip and sanitize every 4-6 weeks. Even still I take a 5 gal can from the house for drinking.
grubbster is offline   Reply With Quote
Old 06-18-2014, 12:26 PM   #10
TURBS's Avatar
Lol I must be an anomaly.
Changed my filter twice a year for the last 13 or 14 years and drink water right from the tap.
Geeze it's well water!
I guess us country folk are used to we'll water.
Any cg I've ever been to has a bill board with water quality testing posted for everyone to view.
I guess it's a city folk thing
Old 06-18-2014, 12:31 PM   #11
Ford Idaho's Avatar
I use a Camco inline as well jut to keep sand and what not out of the system Walmart sells them cheap.
Regulator goes on the spigot and the filter on the other end.
Old 06-18-2014, 12:55 PM   #12
I agree with this. I have yet to change my RV filter cartridge and I change the one that is outside 2x year. No problems so far. Matter of fact the outside one gets capped off with the same little white caps it came with and there is some entrained water in that as it is stored in a plastic tuf with the white hose. The water we drink is again filtered in a Brita jug which does not typically have water sitting in it between trips.
I would not worry about the sitting water if it is treated tap water, but to each his own.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 06-18-2014, 01:15 PM   #13
KyDan's Avatar
You can place your pressure regulator at either end of your hose.
At the spigot might save your hose from bursting due to high pressure.
At the trailer does not protect the hose but you are less likely to drive
away and forget it.
I put my regulator at the spigot.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
KyDan is online now   Reply With Quote
Old 06-18-2014, 01:20 PM   #14
Orion's Avatar
Use a Camco external filter for two-three trips and out it goes and the pressure regulator on the tap to also prevent the possibility of pressure on the hose.
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
Orion is offline   Reply With Quote
Old 06-18-2014, 01:45 PM   #15
cecelea's Avatar
Only put the "blue stuff" in the toilet.
We have a well at home and wonderful water. We use the fresh water tank for drinking, shower, etc....we have a little hard water so we use the filter. Never any leaks or other problems. We empty it in winter when we blow out the lines. Also, if you blow out the lines, make sure to blow the water line to toilet also by holding down the flusher. If you don't the water left in that valve will crack the valve and then there's a mess! I speak from experience! Lol
cecelea is offline   Reply With Quote
Old 06-18-2014, 01:55 PM   #16
bikendan's Avatar
Turbs, i totally agree with you.
for some folks, even city tap water isn't good enough, even though there's been numerous blind taste tests that show that people end up choosing the tap water over the bottled water.
a lot of brainwashing regarding water, has affected our culture. my grandparents would be rolling in their graves if they found out that people pay more for bottled water, than they do for gasoline.
Equalizer WDH
Old 06-18-2014, 02:02 PM   #17
cecelea's Avatar
I agree bikendan, we love our water. Plus I don't like the waste bottle water creates. We do empty our hot water heater between trips so it doesn't start to stink which it will in time.
Old 06-18-2014, 02:05 PM   #18
Kaadk's Avatar
Originally Posted by bikendan View Post
... my grandparents would be rolling in their graves if they found out that people pay more for bottled water, than they do for gasoline.
Mine would just be rolling at the price of gasoline. Have you seen what it's up to lately? Last time I went by the station it was 1.419/litre and predicted to keep climbing. (That's 5.39 / Gallon for you US folks)
I can get 12 litres of bottled water (Case of 24 x 500ml) for 4.99. At today's gas prices 4.99 only gets me ~3.5 litres.
Old 06-18-2014, 02:21 PM   #19
BamaBob's Avatar
*Cough* that should have been installed when you picked up your Rig - a good dealer makes that part of the PDI (showing you how to use the filter wrench and how to turn off/divert water to the filter and Hot Water Heater when it is time for winterizing.)
Yes, install it. It will keep gunk from various water sources out of your plumbing. Believe me, you do not want to have clogged RV plumbing!
Simple answer since you are new: Yes. Black tank, always. Grey Tank, depends. There is specific treatments for the gray tank and black tank (do NOT use black tank treatment in the gray tank...black tank treatments have enzymes specifically to break down toilet paper. It will not hurt your gray tank, it is just a lot more expensive that gray treatment). Really? a couple of OZ of Lysol in the Grey tank will do you fine.
Once you get your RV legs under you, we can discuss various home concoctions that do as good or better than the pre-made RV tank treatments
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 06-18-2014, 03:17 PM   #20
Slympicins's Avatar
We drink water out of the tap, spring and hose. We just prefer the bottled. I have no issues with drinking the water from CG's but would rather walk around with a bottle of water rather than a glass of water. I loose too many glasses that way. Always leaving them at one place or another.
Chuck and Joanne
water, water filter
