Old 04-28-2009, 05:51 PM   #1
Water Heater Heat Build-Up
Our 831FKBSS has the water heater located in the bedroom. For 2009 they removed the vanity and added a triple wardrobe which we like very much. Problem is the center wardrobe seems to be getting heat build-up from the water heater. Does anyone else have this? Anyone have any suggestions? Or should we just not worry?
I understand now they have moved the HWH to the front near the kitchen on the current units.
Mike and Donna
South Central Pennsylvania
2005 Chevy Silverado 2500 HD (gas)
2009 Flagstaff 831FKBSS
(Since June 3,
2008)
Mikesr is offline   Reply With Quote
Old 04-28-2009, 06:27 PM   #2
insulate the tank and compartment with styrofoam, glass batten, bubble wrap, or combination.
turbopuppy is offline   Reply With Quote
Old 04-28-2009, 07:54 PM   #3
milzat's Avatar
I wouldn't use the bubble wrap, but the styrofoam insulation board or glass batten should help.
milzat is offline   Reply With Quote
Old 04-28-2009, 08:42 PM   #4
Cyber Phrenologist
Radio's Avatar
I wouldn't use anything but fiberglass, and probably furnace grade at that.
In the event of fire, the smoke Styrofoam gives off is highly toxic.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 04-29-2009, 06:46 AM   #5
KyDan's Avatar
What HE said!!!!! I know that new water heaters have a styrofoam
case around the tank but if it were my trailer/motorhome I'd put on my
long sleeves and gloves and a paper mask and stuff all the cracks and
crevices around your unit with un-faced fiberglass.
And some heat buildup near the WH is probably normal.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
flagstaff
