10-03-2018, 08:15 PM
Water Heater Quit Working On Gas
Suburban SW6DEL hot water heater quit working on gas over night.
Works on electric so I am not without hot water.
When I try it on gas there is no spark.
Looks like high limit is not out at least when you push it it is solid will not go in any at all.
How do you check the tstat and hi-limit?
The only two things I can see that could be out are the Hi-Limit/Tstat or a bad Module Board. So how do you check these out.
Module Board is going to be hard to access and may require pulling the heater out.
I hope I am missing something simple.
Please post if you have had this problem and found a fix.
10-03-2018, 08:40 PM
Starting with simple, do you have propane? Does your stove work and have a good flame?
This previous thread may be of help and give you a starting point to troubleshoot.
http://www.forestriverforums.com/for...ml#post1827312
2011 Flagstaff 831 RLBSS
10-04-2018, 05:24 AM
When propane quit working overnight, did you have both propane and electric working at same time? If yes, then shut electric and use water to see if propane will light up. Electric comes on first to heat water, then propane when using both at same time.
Fonzie
10-04-2018, 07:29 AM
To add to fonzie's questions... if you had the electric on... how long did you wait (or use enough water) for the LP side to kick on?
On my exact same unit, the electric element gets the water hot enough that I have to use several gallons out of it before it will bring the temperature down enough for the LP to kick on.
10-04-2018, 08:26 AM
Water heater Quit
Water heater was running on gas only.
One full 30# tank and one 3/4 full 30# tank of gas. Plenty of gas and pressure.
Something is preventing the spark from happening.
Tried the reset procedure and it did reset but locked out again several times.
Pulled apart all I could get to and did not find anything that looked bad or burnt out.
Still need to get to the back side where the controller board is to check it out. This will be a major job.
Thank's to everyone who has responded so far.
10-04-2018, 09:17 AM
Kanadian Kamper
Some RV units have access to the control board from underneath the rig.....some from inside the rig behind some panel.
Do you know where you could gain access for your situation?
Ken and Terry
10-04-2018, 11:43 AM
When you reset it, did it spark and try to light?
Gotta go campin!
10-04-2018, 11:59 AM
This is important to know.
If it sparked but didn't light, then it could be electrical or LP issues. If it didn't spark then it is likely a 12v electrical issue or the control board.
You did mention it went back into lockout after resetting. That is usually a good sign that the 12v control portion is functioning somewhat properly.
10-04-2018, 12:00 PM
surburban means bad ignition board . they make the worst boards out there . not uncommon for them to go out . you should be able to see the board from the back of the h/w/h
10-04-2018, 12:02 PM
so your saying it sparked when you reset but no light . could you smell gas? still it's most likely the board as they operate the gas valve to
10-04-2018, 01:00 PM
Our Suburban hot water heater quit working on gas at the August FROG Rally in Goshen. The DSI light was on. Turning off the gas hwh switch and turning back on again caused the light to go out for a short time and then back on again, signaling direct spark ignition failure to light. I could light from outside with a match, but it wouldn't stay lit. No sound of spark during the attempt to start on gas. Fortunately, since we were at the rally, a technician came and replaced the control board, which was located somewhere on top of the unit - easily accessible after removing a panel in the pass-through storage. Apparently this is common enough that bad control board is everyone's first guess on these units.
Rockwood Signature Ultra Lite 8299BS
2011 F250 SD Crew Cab Diesel Fx4
10-04-2018, 04:17 PM
if they light and go out , ie won't stay lit it doesn't hurt to pull the igniter out and clean it off with some emery cloth just don't go crazy . if that doesn't do it then it's the board .I've gotten boards bad out of the box direct from airexcel
10-04-2018, 09:10 PM
Check the propane fittings inside the access door and clean them. Use a fine wire to clean out the pinhole orifice.
10-04-2018, 09:46 PM
Just as confused as you
The service manual for Suburban WH's is in the Plumbing section of the Library.
WH_Service and Training Manual 05-18-11.pdf
Richard & Jill
10-05-2018, 10:20 PM
Problem solved
Installed a new igniter board today. Pulled the old board out and noticed one of the components looked burnt. Purchased a new igniter board from Camping World and installed it. Problem solved I now have gas water heater again.
Thanks everyone for your comments and suggestions.
10-06-2018, 06:43 AM
Glad your issue is resolved and that you came back and reported the fix. It will help others.
Should you ever have another control board issue, check out the boards made by Dinosaur Electronics. Much better quality than OEM boards.
https://www.dinosaurelectronics.com
10-06-2018, 09:08 AM
What did CW charge you ? on amazon you can get them for about $80.
