first more then likely your pump check valve is stuck open. correct this by shutting off city water, turning on you pump and open a faucet briefly. this should reset the check valve, drain some water from the potable water tank and turn the city water back on to test.
I agree you may have a fitting leaking start pulling panels and checking, let the forum know what you find and how you correct it.
Retired Navy
2016 Flagstaff 26 FKWS
