Old 07-09-2014, 03:23 PM   #1
Rick R's Avatar
Water leak in 2013 Flagstaff 30WFKSS
Got back from camping for a few days and decided to repair the damage from a blown tire back in May. The curb side wheel well plastic was torn up so I took a knife and cut the loose pieces and stapled the remainder back up in place with 1/2" pneumatic staples. The water pump was turned on and some time later when measuring for a new piece of plastic wheel well liner I noticed water dripping out. I have a sinking feeling that the water lines run on the curb side from the shower forward to the front kitchen-water heater etc. and I put a staple into a line.
Does anyone know if the water lines are routed directly above the wheel well and if so what is the best way to access them for repair?
I'm thinking block the frame, remove wheels. remove plastic liner and take a hole saw and drill an exploratory hole to confirm my suspicions?
Any thoughts????
Rick R is offline   Reply With Quote
Old 07-09-2014, 05:08 PM   #2
Slympicins's Avatar
Ouch...exploratory camper surgery. I wish you all the luck in finding the leak...
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 07-09-2014, 05:19 PM   #3
Rick R's Avatar
Put everything back together that I didn't need to take apart and I will start fresh in the morning.
Old 07-10-2014, 08:01 PM   #4
Rick R's Avatar
Started looking for the leak today. Took all the new parts I installed yesterday, plus a little more. The water lines run in metal channels and are exposed for about 6" in the wheel well. I believe I stapled through the channel about 10" forward of the exposed section. So only way to repair the lines is to remove the oven in the kitchen and remove the shower stall in the back.
I go back to work tomorrow, so will be next weekend before I try to pull new lines in. Hopefully no more surprises.
ID:	57880   Click image for larger version
ID:	57881   Click image for larger version
ID:	57882   Click image for larger version
Old 07-10-2014, 09:42 PM   #5
Slympicins's Avatar
Wow your knee deep into to that repair. Your will be a qualified RV technician when your done with all that. Good luck with this and keep us posted on your progress.
Chuck and Joanne
Old 07-11-2014, 09:46 PM   #6
polymark's Avatar
I don't know the exact details of your issue but from what I saw from your picture you should be able to just make a cut in the oven compartment, pull it back to where you put the staple into it cut it out and use a "Shark" coupler to rejoin the tubing. Then use a shark connector to rejoin the PEX pipe.
2014 V-Lite 30WFKSS taking life as it comes and loving every minute of it.
polymark is offline   Reply With Quote
2013, flagstaff, leak, water, water leak
