Old 12-17-2018, 07:35 PM   #1
Water line layout 2011 FLAGSTAFF 831RLBSS
Have a small drip located below the outside shower door at the bottom of the cowell where the red and green water line drain pipes are located. (between the bedroom and L/R Slideouts. Just a very slow drip. Would like to know the water line configuration before cutting open the bottom board. Would appreciate any info on how to get the layout.
vicmic83 is offline   Reply With Quote
Old 12-17-2018, 10:34 PM   #2
007matman's Avatar
Honestly, I wouldn't cut it open.
You should be able to remove some screws and drop the entire panel.
Your leak could be coming from another place and pooling there prior to coming out.
It's not that difficult and will save the bottom of your camper from looking like Swiss cheese.
007matman is offline   Reply With Quote
Old 12-17-2018, 10:43 PM   #3
Canadian Member
Any chance you can access the back of the outside shower from the cabinet under the television?
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
flagstaff, water, 2011
