Old 12-02-2016, 11:29 PM   #1
mikdor1's Avatar
Water pumps....
Why are most camper water pumps so loud? Im thinking they are diaphram type pumps and not circulation pumps. Don't they make a quiet water pump for a camper? Hopefully my new 524rlws FR will be quiet because its under the floor!
2017 Flagstaff 524RLWS
2015 F150 , 5.0 , 3:55 axle
mikdor1 is offline   Reply With Quote
Old 12-02-2016, 11:32 PM   #2
They're usually loud because they're mounted on a giant sounding board with nothing to isolate them from that board. You can mount them with isolating bolts and quiet them down. Do a search and you'll find what some folks have done.
Where they're at is a big piece, too. Under your bunk is bad. Opposite end of the TT from where you sleep or hang out is good.
2011 Traverse LT, 3.6L, FWD
Old 12-03-2016, 12:00 AM   #3
Wobbles's Avatar
Best of luck with your wish. So, you are aware of this unspoken pain we live with...
What others have done to fix this is here. In the search bar above enter:
water pump mouse pad
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 12-03-2016, 04:16 AM   #4
bikendan's Avatar
It's usually the pipes vibrating against the cabinets, not the pump itself.
Equalizer WDH
Old 12-05-2016, 04:50 PM   #5
Left Coast
Isolation mounts and a bath towel over it...
Old 12-07-2016, 05:38 PM   #6
Try a different pump. I never stay with the cheapo that came with the rig.
William & Sara
2012 Silverado 2500 HD DA
2014 Cedar Creek 38CK
Sterlingsilver is offline   Reply With Quote
Old 12-07-2016, 05:40 PM   #7
Fulltime family RVer
I'm not too far off from doing this. Going with a quieter pump AND isolating it when I install it.
Old 12-07-2016, 05:42 PM   #8
Pumps with more chambers are quieter. I like the variable speed computer ones.
William & Sara
Old 12-07-2016, 08:27 PM   #9
Our stock Shur flow pump is as quite as a mouse eating cornbread! Youroo! !
Old 12-07-2016, 08:28 PM   #10
Left Coast
X2
Old 12-08-2016, 11:30 AM   #11
NMWildcat's Avatar
I put a piece of firm rubber under ours and then pipe insulation around the connected water hoses anywhere they touched anything or went through to another compartment. Now the only problem I have is hearing it to see when it shuts off after initial priming
Scott and Liz - Southern NM
Old 12-08-2016, 11:34 AM   #12
Ret E-9 Anchor-clanker
donanddona's Avatar
I used part of a towel under it. I check it every so often to ensure it remains dry.
donanddona is offline   Reply With Quote
Old 12-08-2016, 09:43 PM   #13
I'm going to add an accumulator tank to mine in the fall so the pump doesn't run as much. Its awfully loud when someone gets up at night to use the restroom.
2016 Coachmen Apex 288BHS
2015 F150 Sport 4x4 3.5 Eco Boost
4B11T is offline   Reply With Quote
pump, water, water pump
