Old 05-12-2013, 05:14 PM   #1
Dovetail's Avatar
Weak flow via water pump.
Tried to flush out the water tank today and wound up with very weak stream at all faucets.
Put bleach and water into fw tank and filled the lines via city water.
Pump runs but very slow flow.
Did I miss something
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 05-12-2013, 05:18 PM   #2
DAISY BOYKIN's Avatar
Clean the strainer----------------
Did you clean the strainer at the pump? There is a small screen stainer located on the inlet side of the pump, it may need cleaning!
Also check to see if the inlet connections at the pump are hand tight, if loose this could cause your pump to suck air into the system, there fore causing low water pressure.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-12-2013, 05:38 PM   #3
VinceU's Avatar
How bout the 5 or 10 micro whole house filter, if it was left in all winter maybe plugged with ? Remove it for your test and replace if you desire.
Old 05-12-2013, 06:34 PM   #4
Dovetail's Avatar
Thanks for toss ideas Will check it out
2006 F350 SW
