Old 09-17-2017, 05:50 PM   #1
4Daughters's Avatar
Weekend Dilemma
So this past Friday we camped at a state park here in Georgia. The park was a first come/first serve site. I arrived in the afternoon and took a spot that was a little unlevel going uphill and slight right to left dip. The hook ups were on the lower end of the site. I had the nose facing up hill. We use the Anderson blocks for leveling. I could not get the trailer leveled from side to side. It kept rolling off the blocks, I was leveling from the back to account for downhill roll. We got it as close as I possibly could, used my scissor x-chock on the tires, chocked the other wheels and set off unloading and enjoying the weekend.
When I started breaking everything down I noticed the blocks were not under the tire and my front Jack had almost slid off of it's blocks. When I started raising the front to hook up my truck, the dang thing slid off the blocks!! Scared the living poop out of me. Fortunately I had my chains hooked to the truck so it did not go anywhere. After that all else was fine.
Can somebody give me some advice (the nice kind. I do not do well with being blistered on a public forum) on what I did wrong. This has never happen before. We have had the camper since last October.
Could any of the issue be related to the black/gray tanks getting filled?
Thanks for any advice and ask any questions on what I might have missed listing.
BTW- 2017 Flagstaff 831bhds
Thanks!
Also if this belongs elsewhere please move it.
4Daughters
40 miles NE of Atlanta, Ga
2017 Flagstaff Classic Super Lite 831bhds
2016 Chevy Silverado 1500 max tow package
4Daughters is offline   Reply With Quote
Old 09-17-2017, 06:00 PM   #2
If you are on a steep hill you should try to get your leveling blocks level by putting blocks under the low side of the leveling blocks. Then make sure the chocks are level by using long leveling boards that accommodate the tire and the chock or putting additional leveling blocks on either side of the wheel so the chocks are at the same level as the tire. That is what I do. I use 2X6 treated boards to level.
mwdilday is offline   Reply With Quote
Old 09-17-2017, 06:36 PM   #3
When that uneven once you are level or close you can always pull the saftey wire and let the camper lock the brakes till you can get everything blocked really good. I've done this a few times with enclosed trailer and on the race car trailer when having to winch up a really taosted car
Jmkjr72 is offline   Reply With Quote
Old 09-17-2017, 07:10 PM   #4
The_Rhino's Avatar
Our Tri-Lynx leveling blocks have wheel chocks that snap into place. Once the wheel is backed-against the chock, the blocks/chocks cannot move even on a steeper slope. I've used them on state campsites so unlevel that my tongue jack was all the way up...
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2018-25
2017-31; 2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 09-17-2017, 07:40 PM   #5
Zoom's Avatar
Some may think this is not a good idea but before I disconnect the TV with the trailer on a slant I will put some pressure forward and reverse on the chocks. That will let me know if the chocks will hold. Also I will double chock the down hill side. And as the OP said I will usually leave the chains connected just in case. I have never had an issue while doing this.
2015 XLR 29HFS Toy Hauler
2016 Ford F250 Lariat Crew Cab FX4 Power Stroke
2007 Harley Softail Deluxe
2005 Victory Vegas
Zoom is offline   Reply With Quote
Old 09-18-2017, 01:36 AM   #6
Fulltime family RVer
With that kind of unlevel, I'd want better chocks than the Andersens. I personally use a combination of the LynxLeveler chock/blocks and heavy rubber chocks.
ependydad is online now   Reply With Quote
Old 09-18-2017, 05:37 AM   #7
wmtire's Avatar
Yes, the solid rubber chocks that Harbor Freight sells, seem to work real good, and aren't as prone to sliding on concrete as the plastic kind. If your trailer was sliding off the blocks as you described, then it wasn't chocked well enough.
https://www.harborfreight.com/solid-...ock-96479.html
I carry four and place then in front of the front axle tires and behind the rear axle tires before unhooking from tow vehicle, which works similar to how The Rhino has his pictured above.
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 09-18-2017, 05:57 AM   #8
I always keep a set of 4 1x8's to put under wheels for pads like that and I like the Rubber chocks better than the plastic...as others have said...less prone to sliding on concrete or asphalt.
TheWolfPaq82 is offline   Reply With Quote
Old 09-18-2017, 06:00 AM   #9
jeff64's Avatar
X 2 here
I only have one of the lynx chocks for the downhill side and chock the other side as well.
Also use the camco version of the bal wheel locks. Those go on before I disconnect
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-18-2017, 06:10 PM   #10
4Daughters's Avatar
Thanks for the input guys!! Looks like a combination will work. Definitely getting the rubber blocks first.
4Daughters
Old 09-18-2017, 06:47 PM   #11
B and B's Avatar
Plastic Chocks are sales gimmicks. Rubber chocks all the way!
B and B is online now   Reply With Quote
