Old 11-24-2019, 08:44 AM   #1
mudman2's Avatar
Weight capacity for flat screen tv
Any idea how much weight the television clip on outside trailer wall will hold.i have a 2019 25bds
Microlite
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 11-24-2019, 09:32 AM   #2
Which mount do you have? A picture would help if you don't know the model.
If it's a Paw International mount they are normally rated for 30 lbs.
Gotta go campin!
Old 11-25-2019, 09:37 AM   #3
mudman2's Avatar
Here’s a pic of mount.
2015 tundra
Old 11-25-2019, 09:45 AM   #4
Originally Posted by mudman2 View Post
Attachment 219818
If that is Poly/plastic, it is a PAW mount and rated for 30 pounds as Bama Rambler mentioned.
PAW also makes a similar model out of metal.
It DOES NOT mate with the PAW Poly model but I have read they claim it is good for 40 pounds.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 11-25-2019, 11:23 AM   #5
mudman2's Avatar
Thanks to the response. I’ll check if it’s metal or plastic. My main concern was pulling on wall behind bracket.
2015 tundra
Old 11-25-2019, 12:14 PM   #6
They supposedly put a solid wood backer behind the filon where the mount is located, so with the right screws it'll hold a lot more than the mount will.
Gotta go campin!
Old 11-25-2019, 12:35 PM   #7
Unless you plan to modify the mount and set the weight out away from the wall a good bit, it will hold just about any tv.
The design of the mount is for vertical shear. It really doesn't pull on the wall much unless you get the mass out away from the wall.
weight
