Old 02-13-2015, 01:53 PM   #21
Our TV is a 2004 Toyota Seqouia 4x4 with tow package. The trailer is 2011 MicroLite 23LB. I believe the dry weight is around 3700 pounds.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 02-17-2015, 09:11 PM   #22
Thanks for all the feedback now one last question....when I get one is this something I can install myself?( I'm pretty handy with tools so no prob there)
cruiser1701 is offline   Reply With Quote
Old 02-17-2015, 10:10 PM   #23
ChibullsAN's Avatar
There are plenty of videos and instructions on youtube. They aren't that hard if your handy and have common sense. I guess It depends on which one you get.
2018 Rockwood Signature Ultralight 8329SS
ChibullsAN is offline   Reply With Quote
Old 02-17-2015, 11:32 PM   #24
Blog: RVroadtripper.com
hbillsmith's Avatar
I see someone is offering an almost new Andersen for sale on the classified ads portion of this forum. $300 is a good deal. Its the same model I used for three years. It also was incredibly easy to install and maintain.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 02-18-2015, 07:31 AM   #25
If you are pretty handy, you should have no problem with most of them. The only thing you are likely to run into is having the correct tools for the job. I can't speak for some of the models, but I know for a fact that you aren't going to be able to setup an Equalizer with a standard set of tools. I don't even remember what size socket you need for the ball, but it is big. I think the shank bolts are 1 1/8". Torque specs are really high, too. I think the ball I used was 450 ft. lbs. I used a cheater bar for this- me at just over 2' out equals 450 ft. lbs.
Old 02-18-2015, 08:11 AM   #26
hbillsmith's Avatar
I agree with DUSTMAN. For the Andersen you will want to have a Torque wrench. The hitch includes the special socket but you need a 3/4" torque wrench. I picked mine up on the internet from Harbor Freight for $20. It was cheap enough so I just keep it in the trailer.
Old 02-18-2015, 08:38 AM   #27
Harbor Freight 1/2" Torque wrench-#239 (21.99$), 3/4 Torque wrench #808 (79.99$) Youroo!!
Old 02-18-2015, 10:41 AM   #28
hbillsmith's Avatar
Torque Wrench for Andersen WDH and Wheel torques
3/4" Torque Wrench
You need a Torque wrench that provides 100 ft. lbs. setting. This is the Harbor Freight one I use.
3/4 in. Drive Click Type Torque Wrench. Pittsburgh Professional - item#808. 3/4 in. torque wrench provides a range from 50 to 300 ft. lbs. Only: $89.99 Sale: $79.99
It was a sale price of $19.95 free shipping when I bought it, at their current price you might as well just pick up one at Home Depot or Walmart. While you're at it, go ahead and get a cheap set of sockets, then you are set for torqueing your wheels too!
Here's the link for the Andersen WDH Installation Manual. It references the 1 1/4" Socket that's included in the package.
http://www.andersenhitches.com/uploa...02013%20sm.pdf
Old 02-18-2015, 12:47 PM   #29
Thanks I already have the torque wrench from when I used to work on cars now while we are on the subject of Harbor Frieght Tools I noticed that they have a Haul Master weight distribution hitch it's rated at 1000-10000 lbs is this any good or should I keep looking
Old 02-18-2015, 01:13 PM   #30
hbillsmith's Avatar
I have no experience or familiarity with the Haul Master, sorry. I like the Andersen because it was the lightest and my car's hitch weight allowance was pretty skimpy. Also, the Andersen seemed easy to install and operate when I traveled. It's definetly not the least expensive. New their over $500 and used you'll find them for about $300.
hitch, weight
