Old 03-12-2017, 03:31 PM   #1
Cmccul's Avatar
What type of roofing material do I have?
I am trying to find out what type of roof I have. I have a 2015 26RLWS. Where do I find this info? I looked through my paperwork and couldn't find it.
[/SIGPIC]2015 Flagstaff 26RLWS Emerald
2014 Chevrolet 1500, 4 X 4, 5.3
73 nights in 2017
74 nights camped in 2016, 121 nights camped in 2015
Cmccul is offline   Reply With Quote
Old 04-04-2017, 12:28 PM   #2
If it's textured it's most likely Alpha, otherwise EPDM.
2017 Ram 1500 Sport 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 04-04-2017, 12:36 PM   #3
Steeljag's Avatar
Our 2010 had the Rubber roof !
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 04-04-2017, 12:47 PM   #4
saus's Avatar
When we bought our new 5er I had the same questions. It did not tell me in any of the paperwork. To know for sure, just go into the bathroom and remove the trim around the fan. Your roof material will be overlapped into the opening. All you have to do is look at the back side of the material. If it is black you have an EPDM roof. If it is all one color it will be TPO.
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
saus is offline   Reply With Quote
Old 04-04-2017, 03:20 PM   #5
Here is what Alpha, the manufacturer of most TPO/Alpha-Ply roof material FR uses has to say in their FAQ...
"Do I have a rubber roof membrane?"
"Rubber roof (also known as “EPDM”) membranes are smooth. TPO and Alpha-Ply roof membranes have a haircel texture, which can be likened to an orange peel."
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 07-08-2017, 02:57 AM   #6
Novice Travel Trailer Guy
benchmarks's Avatar
I used to work for a manufacture of these products. All new trailers are using thermoplastic polyolefin. It's been around for a little over 20 yrs, but has had many formulation changes. Regardless it is the most widely used single ply roofing membrane used for commercial building enclosures. Bottom line the raw material costs are cheaper, therefore the value engineering is used. The third generation product holds up well to grease and other chemicals. It is easy to repair any holes that may occur. Pressure sensitive tape is used or it can be heat welded. Any building supply distributor will have some. Carlisle, Firestone, JM all make it. Like any single ply just make sure to inspect sealant as it is a maintenance item that shrinks over time due to UV. What happened to EPDM you say? Well nothing it is still around but just the price per sqft is more. The sheet goes back to the late 70's. The true EPDM is black and has great elongation properties. The white sheet does not have as long if a track record. It is more in line with 20yrs. Carbon black is what makes it a good performer. The white has titanium dioxide in it to make it white. EPDM come reinforced and non-reinforced. You want the scrim in the sheet to give it greater puncture strength and tear resistance. In the trailers the non-reinforced is/was always used to keep costs down. Repair of it is a little more dependent on making sure the sheet is very clean prior to tape being used to repair, like a bike tire patch. It cannot be manipulated with heat as that will break it down. EPDM is not as chemical resistant as thermoplastics. Any grease or petroleum will cause a failure of the physical properties. Painting the rubber will prolong its life.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
roo, roof
