Old 04-30-2017, 01:15 PM   #11
Originally Posted by 2Evil4U View Post
2016. Yes the plate was in the wall for the bedroom TV. The tv above the fireplace is mounted into wood with many small screws. I had to modify the OEM mount to fit the replacement I installed for the living room.
Thanks!!!
festiveford is offline   Reply With Quote
Old 04-30-2017, 02:48 PM   #12
TV MOunt
On mine (373 QSI) during the PDI, the tech pressed on the wall at that point, "Here's your TV mount spot." He pushed on it, and the wall depressed deeply. I removed the plug plate, and stuck a small inspection mirror in there. NO backer. Nearest stud is about 8 inches away. I might bridge between studs with a 3/8 narrow strip of plywood and mount to that, but that wall is nothing but tissue paper.
hankpac is offline   Reply With Quote
Old 04-30-2017, 02:58 PM   #13
Oops, that's not good.
Old 05-04-2017, 12:19 PM   #14
I believe the spot in mine that's labelled "TV mount" is also just hollow. I have no plans to mount one in that spot as it's for a second TV but it still seems cheesy to label a spot that isn't what it says it is.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 05-10-2017, 02:37 PM   #15
I received this reply from Forest River regarding "what's behind my wall" that says TV Mount!!!
Good morning,
The tv backer will be marked by a sticker. The sticker will mark then center of a 10 by 10 aluminum backer if the sticker is on an exterior wall, if it is on an interior wall it will be a 10 by 10 plywood backer. Unfortunately we do ot have a diagram for this.
Since it is an exterior wall, ours will be aluminum..... should I use metal screws?
Old 06-05-2017, 06:28 PM   #16
Ditto!
Originally Posted by Martsing View Post
In my case there was only empty space behind that sticker.
Marty
Ditto on that !
oldstairdog is offline   Reply With Quote
Old 06-05-2017, 06:35 PM   #17
I would have the dealer install it! That plate is thin and while drilling a pilot hole it poked thru the outside..... now I think an install would be cheaper then a gel-coat repair
Old 06-05-2017, 06:52 PM   #18
llr
I would just get the drill point screws, as large as you can find that's about 1 inch long
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 06-05-2017, 06:53 PM   #19
Just as confused as you
Scrapper's Avatar
On my 2014 832IKBS there was a metal plate. Be sure you use a stop on your drill bit to keep from going to deep. You can wrap several turns of electrical tape on the drill bit or you can get a bit stop collar from a hardware store. If I remember right the outside wall is only 1-3/4 inches thick. Check where the door latch is to be sure. I used 1-1/2 inch self tapping sheet metal screws and drilled the holes with a 1/8 inch drill bit.
Richard & Jill
2014 Flagstaff 832IKBS - seasonal
2011 Silverado 1500 Ext Cab Z71 4x4
Camping since 1989, seasonal since 2009
Old 06-06-2017, 08:29 AM   #20
Pickin' & Campin'
This was what mine is as well.
My backer on the exterior wall was metal and I could easily find the size by placing a magnet on the wall.
I was also told by the factory that if on the exterior it would be metal (not aluminum as mentioned earlier) and use a magnet and wood if on an interior wall.
Keep in mind while there was a metal backer in the wall, it is VERY thin and pushing on the wall results in flexing just as if nothing was behind it.
The suggestion of a drill stop is good advice. I drilled mine expecting a much thicker piece of metal and so was pushing fairly hard. When the drill went through easily, I was glad I had a drill depth stop on.
Days Camped: '15=22 '16=46 '17=30 '18=13
mount, tv mount
