Originally Posted by Timex
of course a water pressure regulator on the faucet outside.
I think it is in your water pressure regulator.
Picture it as side A (in) which is the campground side....then your regulator......then side B (out) which is your trailer.
Your regulator could be limiting pressure by controlling flow. When first opened, it allows flow with a limited pressure. It allows side B to be the pressure that the regulator is set for.
While showering, when you flush the toilet at the same time the pressure drops enough on Side B that the regulator allows more flow by opening more.. When the toilet valve is closed the pressure does not rise enough on Side B to create a problem so the regulator is staying open...so more water is flowing in and you see it in the shower..
Once you turn the shower off, the pressure builds up enough on side B, that the regulator closes to maintain the pre-set pressure.....so you are starting all over again the next time you use the shower/toilet combo.
It should be easy to test. Take the regulator out and try the same scenario to see if the difference goes away. That way you know it’s the regulator.
http://wiki.answers.com/Q/How_does_a...regulator_work
You also might want to consider replacing the regulator, especially if it's one of the $10 kind.
