Old 04-07-2010, 11:27 AM   #1
ljeast's Avatar
Which Dump Valve is which?
Hi Y'all,
I am new to RVing ... I purchased a 2010 8528RLWS in Dec. and cannot tell which valve is for Black and which is Grey. Their is no specific label for each. One is recessed back a good bit and there is a label above that says Waste Water Dump Valve. It's all waste water to me so that doesn't tell me anything definite.
Can anyone help.... Is there some identifying factor that works for all RV's? Short of filling a tank and testing - How do I find out? The manual is no help. Yes, I asked the PDI tech and he was not sure.
Thanks in advance for any help
LJ
ljeast is offline   Reply With Quote
Old 04-07-2010, 11:42 AM   #2
Grape Escape
Dump valves
If you can see piping from below easiest way would be:
3"-4" would be black water
1 1/2" would be grey water
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 04-07-2010, 04:24 PM   #3
tmmar's Avatar
Take a close look at the handles. On mine, the grey water is a (dark) charcoal grey color and the black tank is black.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 04-07-2010, 07:42 PM   #4
Steeljag's Avatar
If you can get down there and look....the larger of the two valves is the BLACK water.
Steeljag is offline   Reply With Quote
Old 04-08-2010, 06:31 AM   #5
Herk7769's Avatar
OK had the same issue on my 8526RLWS. Since the handles are unlabeled and identical, the one closest to the dump mast is BLACK water. It is also further out from the frame. The one to its left is the grey water and it is inset (less out). I wound up labeling mine but I used Dymo thermo labels. The sun makes them white again in short order. I had a hell of a time cleaning the label glue off the camper.
HAM CALLSIGN - KC3FFW
Old 04-08-2010, 07:32 AM   #6
cardinal4fun's Avatar
Just fill one and pull, I had the same problem as I have one black and two grey. Once I figured it out took a piece of electrical tape (black) to mark that handle and a piece of duck tape (grey) to mark the other.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 04-08-2010, 11:44 AM   #7
jaxfl's Avatar
You are lucky, you only have 2 handels. I have 3. Black, Gray bath and gray Kitchen. But to answer your question the largest is the black.
jaxfl is offline   Reply With Quote
Old 04-08-2010, 02:41 PM   #8
CLASS "A" Senior Member
cfsoistman's Avatar
Same as residential plumbing. Small drain line from sink or tub 1-1/2", larger drain line 3" from toilets.
We have 2 of each with our Bath and a half. One group mid coach is 1 toilet, bathroom sink and kitchen sink. Second group closer to the rear is 1 toilet, 2 vanity sinks and 1 shower. 4 valves total. I keep a spare for each size. I hope it never breaks with a full black tank and I bet no one around me does either.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-09-2010, 06:03 AM   #9
Herk7769's Avatar
Using the pull one and see method is how I figured it out.
I put a clear 90 degree fitting on and looked at the discharge. Pulled gray water first to make sure there were no leaks. Then stopped the flow. Pulled black water to fully dump. Then pulled gray again to flush out the hose.
Old 04-09-2010, 02:45 PM   #10
fivecodys's Avatar
On our trailer the one closest to the fitting is the black.
It has been that way on the last two trailers we have owned.
I don't know if that is a standard or not.
Bill
2009 Flagstaff 8528 RKSS
2019 GMC 2500 HD Diesel
Pullrite Superglide 14K
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 04-24-2010, 02:04 PM   #11
ljeast's Avatar
Thanks so much everyone for your replies....
The whole bottom is sealed so I could not see the size/s of the pipes and both handles are black. I did get a 45 degree clear extension for the pipe and test dumped the farthest left one - it was indeed the grey tank.
I love the duck tape idea - Thanks I've installed it behind my grey handle.
I do also have a 3rd, galley tank and am very surprised they did not somehow connect both grey tanks for ease of dumping.
I do Love the new rig though. Took it on the first trip to Hot Springs on derby weekend and it handles great.
Again, thanks for all you thoughts.
Linda
TV: Luna
2010 F150 XLT/SCab/6 1/2'/4x4 5.4L/3.55
Class IV Factory Tow Pkg 7200# GVWR Pkg
Rig: Shangri-La
2010 Flagstaff 8528RLWS
Valley 16K Dbl Pivot Slider
Valley Journey HD Brake Controller
...Experiencing and having fun
Old 04-25-2010, 06:38 AM   #12
Herk7769's Avatar
Linda, I posted photos of the tank plumbing previously.
Here are the links so you can see what is going on inside the frame (plumbing wise)
The gray and black tanks
http://travel.webshots.com/photo/238...w?vhost=travel
The galley tank
http://travel.webshots.com/photo/240...V?vhost=travel
I did not take the pics; someone at Forest River did.
In the first photo; if you look closely you can see the rod that connects the handles to the valves. Also note where the sensors are for the liquid levels.
Old 04-26-2010, 06:03 AM   #13
ljeast's Avatar
Here are the links so you can see what is going on inside the frame (plumbing wise).....
Thanks, that does help a lot.
Linda
TV: Luna
Rig: Shangri-La
flagstaff
