Not sure if you went with the 31 bdhs or not. Few things to consider if you did. Upon set-up if you have the outdoor kitchen try level so water falls rear bunk side. If happens to fall over outdoor kitchen the water splashes off the lid
. No biggy easy fix, I took to plastic water bottles cut the bottom off each and slide together. The drinking side of bottle fits perfectly on your drip eves extension
. I think all are equiped with extension.
A handy tip, the exterior front storage door on the awning side. 2011 only have lockable entrance, I installed an additional "thumb lock" (no key required) as this is the storage I access the most.
owner of 2011 31bhds outdoor kitchen and love it.
