Old 09-08-2019, 08:45 PM   #1
Dmax07's Avatar
WiFiRanger Sky3 no access to control panel
WiFiRanger Sky3 on line but can't access control panel.
Is there a hard reset button on the roof top unit to Factory Reset the unit.
Is there another way to Factor Reset the unit.
Turning off and on with 80 second intervals three times dosn't work.
Dmax07 is offline   Reply With Quote
Old 09-17-2019, 12:36 PM   #2
If I understand your question correctly, you are trying to log into the Ranger to do something. Resetting it won't give you access to the control panel. In order to access the Ranger functions, you have log into it using a web browser, using the Ranger's IP address and the password. There should be a sticker near the power switch with the IP address and password scheme - the same information is in the manual. Since the Ranger is powered up, enter the IP address into your favorite browser and it will prompt you for the password.
t.simpson is offline   Reply With Quote
Old 09-17-2019, 03:53 PM   #3
Dmax07's Avatar
I've logged in and used it for over a year now. This past trip a couple of weeks ago I logged in and out. The next time I tried to log in it wouldn't log in with any of my devices. I tried to reset it to factory specs by turning it off and one several times as per some instructions I found on the internet. Still no luck it would not reset to factory. It still comes on and you can see it's name in the list of wifi accesses but no luck signing in.
I need a way to reset it to factory spec's or a way to get into the control panel.
It may be a lost cause at this point.
Old 09-20-2019, 01:26 PM   #4
Ok, I understand. To me, it sounds like something was changed - maybe a password change?
Old Yesterday, 01:25 PM   #5
Have you looked at the manufacturer's web page?
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
- 1969 Coleman Williamsburg (used, with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 2020 Rockwood 2507S on order for November delivery.
chriscowles is offline   Reply With Quote
wifi
