Old 10-01-2017, 09:23 AM   #1
wayfaringgirl's Avatar
Will battery power slide out and in?
If this is a dumb question I apologize in advance...
I will be moving to another volunteer location in a couple weeks and am thinking of staying at a campground with no hookups one night. Will the single battery have enough power to get the slide on my Flagstaff 25BHS out and then back in the next morning? My trailer isn't a whole lot of fun to be in when the slide is in. I would be very frugal with my battery use.
Thanks for any help.
Gale
2018 Crusader 315RST
2017 Flagstaff 25BHS
2011 Toyota Tundra
wayfaringgirl is offline   Reply With Quote
Old 10-01-2017, 09:51 AM   #2
rebeltown's Avatar
I'm sure a whole lot will depend on how much energy you use during the night as to whether you have any left in the morning... If you're frugal you should be fine and you should be able to manually retract them if you have no power in the morning.
2017 Rockwood 2304DS Ultralite
2012 F-150 4X4 XLT 5.0 V8
rebeltown is offline   Reply With Quote
Old 10-01-2017, 10:02 AM   #3
Kasual Kamper
If the battery is weak, you can always hook up your tow vehicle to draw off of your vehicle's battery.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 10-01-2017, 10:36 AM   #4
Grammar Pedant
67L48's Avatar
It better. Otherwise, you could only use this trailer in a campground with power hookups. That would be terribly restrictive. If your battery won't power the slide, then there is something wrong with your battery. The converse should be true: if your battery is in good condition, then you should have plenty of power.
But, as said, this depends on your behavior. If you turn on all your lights for 4 hours, run your furnace all night long, take a long shower running the water pump, etc., you could burn through your battery.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 10-01-2017, 12:29 PM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
Worst case is to remove the battery from the truck and use it to close up the RV.
donanddona is offline   Reply With Quote
Old 10-01-2017, 12:34 PM   #6
Use jumper cables from your truck battery if needed. That will carry much more power than the trailer lights connector. But your battery may do it alone if not run down overnight.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
CedarCreekWoody is offline   Reply With Quote
Old 10-01-2017, 12:42 PM   #7
Thank you for all your replies. I checked the water level in the battery and the charge as well - it read 13.17 so I should be starting with a healthy battery and will make sure I keep that way while traveling.
Thanks!
Gale
2011 Toyota Tundra
Old 10-01-2017, 12:44 PM   #8
I keep a jump starter with me, works on my truck and trailer if needed. Just a thought.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 10-01-2017, 12:44 PM   #9
15 -21FBRS 17-F150 2.7 e
J.Fallon's Avatar
answer is
Yes
J.Fallon is offline   Reply With Quote
Old 10-01-2017, 12:49 PM   #10
I've run into that situation several times and the only thing I do (maybe for my own peace of mind) is to have the truck running when I put the slide in and out. It doesn't amount to much, I guess but what the heck!
PapaWayne is offline   Reply With Quote
Old 10-01-2017, 01:01 PM   #11
satdog01's Avatar
Run kitchen slide out while traveling all time. Only way you can get into refrig. Same with power jack, disconnect tt from truck on battery as well. You have done the right thing in checking voltage and water levels. Do not want to start a heavy discussion here, but read somewhere that tow vehicle electrical should not be connected when shore power is hooked up. So disconnect tv before shore is connected.
2020 Georgetown 31L, Safe T steering, Onan Geny
2015 GMC Canyon TOAD w/Blue Ox tow plates
Pepper 🌶 Pomeranian rescue 327 nights as camping buddy
Days camped in FR, 2011-12 = 77, ‘13-14 = 98, ‘15 = 52
‘16 = 77, ‘17 = 81, ‘18 = 44, 19’ = 83, 2020 = 30 booked
Retired :
satdog01 is offline   Reply With Quote
Old 10-01-2017, 07:59 PM   #12
DanLE
I ditto posts #10 and #11. We always power the slides in or out while connected to the tv wiring receptacle if we're doing a Walmart type of quick overnight. Then I'll also always unplug from the tv to prevent unplanned discharge of both house battery and starting battery unintentionally. I start the tv in the morning plug in the wiring harness and then close the slides. Never had any problem using that approach so far.
DanLE is offline   Reply With Quote
Old 10-01-2017, 08:21 PM   #13
Part-Time
Amen to that
X2
mwtracht is offline   Reply With Quote
Old 10-01-2017, 09:11 PM   #14
CaptnJohn's Avatar
That is true with GM and Ram. At least the newer Fords will not drain the battery if plugged in and ignition is off.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 10-01-2017, 09:11 PM   #15
I mounted a neat voltage monitor that displays voltage and alarms at whatever voltage you set it at. Works slick. Wakes me to start generator before battery too low to start it. Especially valuable when running furnace as battery drops to alarm level in 4 hrs or so. Saves generator fuel and hours on generator.
tuxedo is offline   Reply With Quote
battery, power, slide, slide out
