Old 06-29-2015, 12:39 PM   #21
PhoneDude 8289's Avatar
Originally Posted by Casual_T View Post
I have a 2000 Tundra with same engine and tow a 21' Minilight. While it tows ok I don't think I would want to tow anything larger. Mine has only a 350lb tounge weight, the suspension is horrible on the Tundra and no cheap improvements. A weight hitch may help enough but your most likely looking to get air bags or the rear will be sagging alot!
Good shocks, airbags and E rated tires will fix the suspension but it will not increase payload.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 06-30-2015, 07:09 AM   #22
I have an 04 tundra and 21fb. I wouldn't want to tow anything more thru the Pennsylvania hills. if I head to flat ohio its a breeze. the truck does fine you just need to run the rpms up on the hills. wdh is a must. I towed a couple times without it and I have airbags but it is worth the money. mine has a dry weight of 3500 so I figure reality of 4000 plus my wifes 1000lbs of sh.... I mean necessities. if your in a flatter area you should be fine
2013 21fb micro lite
2004 Toyota tundra
heyjimi is offline   Reply With Quote
Old 07-02-2015, 07:33 AM   #23
dcheatwood's Avatar
The op has an '02 tundra. The largest engine available then was the 4.7 v8.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-07-2015, 10:54 AM   #24
PSUFan1's Avatar
I towed a 23lb with a gmc envoy 4.2 I6 with 5,000 towing capacity and a v8 version 5.3 liter with a 6,100 towing capacity.
The I6 did ok for short trips and non-hilly areas but dogged it on the mountains
Then upgraded to the v8 version and did a lot better and drove from PA to Niagara Falls last year. We wanted more capacity for my next trailer so we upgraded to a F150.
I think you should be in good shape.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 07-07-2015, 11:16 AM   #25
Well........FWIW, we pull our 30' Rockwood with a 2014 Tundra with the "Little" 4.6L. ......seems to work just fine around this area (Mi./Ohio/Ind.).....WDH of course
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 07-07-2015, 11:22 AM   #26
Pull a 25 ft Wildwood weighing 4885 dry 5400 lbs give or take loaded with an 03 Tundra V8 towing pkg WDH flats are a breeze it's the mountains that it slows down but then again I don't beat on it. After we pay for our daughters wedding in Sept will start looking at Dodge Rams.
VT Skier is offline   Reply With Quote
toyota, tundra
