I winterized several weeks ago.
Drain the Hot Water Heater
Drain the Fresh Water Tanks
Turn 2 Valves, 2 at the Hot Water Tank, cold water in, Hot water out to off.
Turn valve at water pump, to direct pump to Anti freeze siphon inlet.
Make a short hose with male hose fitting to screw onto antifreeze siphon inlet.
Fill bucket with about three gallons of pink stuff, put hose end in bucket or siphon from gallon jugs.
Turn on water pump,Turn on each faucet (hot and cold) one at a time until pink come out, fill toilet too, don’t forget outside shower. Pour a little extra pink in each drain, and toilet.
Remove Battery, store indoors on wood not concrete.
Close all vents, lock doors and windows, cover if desired and wait until spring
If I forgot something, maybe someone else will chime in, Good Luck!
Bob & Laurie w/Missy
Sayre, PA
2016 Flagstaff Micro-Lite 21 DS
2015 Ford Explorer
