Old 08-26-2014, 06:50 AM   #1
Winterize with hose connector
I can image this being covered time and time again however I would like to know exactly how to hande this process.
Do you remove the water filter before you winterize, what are the steps for the water heater?
Is there any videos out there for the complete procedure?
How do you handle the outside sink?
Do you flow out the lines first then add antifreeze?
Ive never winterized with a water filter and new hose connector in the rear.
Sorry of this was covered before.
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 08-26-2014, 07:32 AM   #2
Witch Doctor's Avatar
You close your inlet valves to the W/H hot and cold and open the bypass, you also close your fresh water valve. Hook the hose in the connection and suck the pink stuff out of the bottle through you water pump. Open all the faucets and wait for pink to come out, let some go into your holding tanks and then that's it. Do not put it in your fresh water tank, just drain it. Pull your relief valve on your hot w/h and the take the galv. rod out and flush some water through it. Then you are done should take about 3 to 4 gals of the pink antifreeze. you will find these valves behind the w/h and you might need to remove a panel for access and then look for the fresh water valve it will be there pretty close and it will just be valve on a white hose not your plex lines. Hope that helps, takes about a 1/2 hr to do.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 08-26-2014, 07:04 PM   #3
Slympicins's Avatar
Yes...remove your water filter before you add antifreeze. It's a simple process. When you run the antifreeze out of your faucets, make sure enough gets into your p traps (kitchen, bathroom sink, shower. Drain your low water drains.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 08-26-2014, 07:06 PM   #4
heavynlori's Avatar
Don't forget your washer hookup connection even if you do not have a washer installed .....And your outside shower too !
heavynlori is offline   Reply With Quote
Old 08-26-2014, 07:10 PM   #5
Slympicins's Avatar
I also forgot your outside shower. Make sure to drain that too. Haha. It's still not a tough process. Just a lot of stuff to do. I have it down to about 10 minutes since I did it several times last winter. Even though there was snow on the ground, we still did a little camping.
Chuck and Joanne
Old 05-30-2015, 09:56 AM   #6
Also burp you city water hose hookup outside once the unit is pressurized with antifreeze. Do this by removing the small screen and use something to poke in there to depress the back valve. there is usually water that stays trapped in there also.
Bojanglespa is offline   Reply With Quote
winter, winterize
