Old 09-23-2018, 07:37 AM   #1
dieseldodge's Avatar
Wishing I could weigh my Flagstaff
Recently took our 2019 Flagstaff for a 400 mile trip into the mountains. Have not yet replaced the Castle Rock tires it came with (why should have to replace them already?). Well, I have to tell you when you are shooting down 6 and sometimes 8% grades with no guard rails with tires that have a poor reputation.....I could think of nothing else.
We obviously made it home in one piece, but with a keen interest in RV tires. I decide to learn the tire weights on our RV. When we still lived in small town Nebraska it was easy to do. The local grain elevator left their scales on all the time so I could go there and get all the weights I wanted. But down here in southern New Mexico I can't find a scale that is flush with the ground (wouldn't it be great if RV dealers offered such services?).
I have one of those tongue weight scales for my bumper trailers, been trying to think of a way to learn the weights of our RV without spending $1800 for a Walz load cell scale. Any ideas. (BTW, our 8529IKBS has the Torflex axles)
A thought that occurred to me while going down those steep grades. With no place to air up the tires when in the cool mountains, we were probably running on 'under' inflated tires until we got down to warmer temps.
dieseldodge is offline   Reply With Quote
Old 09-23-2018, 07:45 AM   #2
W5CI's Avatar
Take it to your local Truck Stop, they will probably have a Certified CAT Scale.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 09-23-2018, 07:45 AM   #3
fonzie's Avatar
Just go to a CatScale near you...
https://catscale.com/cat-scale-locat...s=2&cmdSearch=
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 09-23-2018, 07:48 AM   #4
All the truck stops that I have checked out have above ground scales
Old 09-23-2018, 07:49 AM   #5
nomad297's Avatar
It would be great for us, but not so great for the dealers who tell customers they can pull that 40’ toy hauler with their Smart Car. RV sales would decrease by 75% if educated (in towing) buyers had access to a scale at the dealer.
Bruce
nomad297 is online now   Reply With Quote
Old 09-23-2018, 08:38 AM   #6
Blackrock's Avatar
And how is this a problem? We all weigh our rigs on the CAT scales.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 09-23-2018, 09:12 AM   #7
Also will mention. The castle rocks are fine, if you treat them right. I towed from Houston to Rocky Mountain national park without any tire issues.
The reason tires blow out is people underinflate them for the load, overload them and drive at too high of a speed. Also scrubbing them when turning hard is hard on the tires, and hitting rocks etc when backing them in. See a lot of people not towing level too which overloads the front axle on the trailer leading to blowouts. Can’t tell you how many times I see people not towing level or running clearly under inflated tires. I point it out to folks when at gas stations when I see them. Also watch for sun rot. This applies to any trailer tire, and your tow vehicle. See folks all the time with under inflated tow vehicle tires....
I’ve had my trailer maxed out at 5300lbs, with the tires inflated to 50psi and running at 70mph in 105 weather in the pan handle. I’ve driven the trailer for thousands of miles and the tires have been fine. But I tow level, check the pressure, have a special pump for inflating them, and don’t exceed 80mph in hot weather for long periods of time. My tow vehcile rear axle tires are rated at 2300lbs each at 50psi, and I keep them at 44psi with about 2000lbs on them.
People who are blowing out the tires are probably underinflating for the load, driving too fast for the speed rating, or unlucky with obstacles.
thecastle is offline   Reply With Quote
Old 09-23-2018, 09:16 AM   #8
Thurman's Avatar
I believe that I understand where "dieseldodge" is coming from. I'm in SW GA. that has no public access to a set of scales to weigh an RV on. There are numerous truck scales here which are owned by private businesses, one private inert landfill scale, two County owned scales at landfills, and one CAT scale. The CAT scale here WILL NOT allow public weighing. If it is not a commercial vehicle with paperwork then they will not allow you on the scale. There is a large sign at the entrance to the scale stating this and I have gone in to talk with the person on duty. Why they won't allow public weighing no one knows, they just state "those are the rules". The closest public access scales that I know of are about 75 miles away, another CAT scale at a Pilot truck stop.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 09-23-2018, 09:58 AM   #9
With an above ground scale all you will learn is the total weight of your rig...nothing more. I've already got a pretty good idea of that with the info the manufacturers provide. How am I to learn side to side weight...and even better the individual tire weights?
Our 2006 Wildcat had two slides, both on the drivers side. Guess which side had the most weight on the tires?
Old 09-23-2018, 10:21 AM   #10
Denver To Yuma In 90 Days
The reason tires blow out is people underinflate them for the load, overload them and drive at too high of a speed. Also scrubbing them when turning hard is hard on the tires, and hitting rocks etc when backing them in. See a lot of people not towing level too which overloads the front axle on the trailer leading to blowouts. Canít tell you how many times I see people not towing level or running clearly under inflated tires. I point it out to folks when at gas stations when I see them. Also watch for sun rot. This applies to any trailer tire, and your tow vehicle. See folks all the time with under inflated tow vehicle tires....
Iíve had my trailer maxed out at 5300lbs, with the tires inflated to 50psi and running at 70mph in 105 weather in the pan handle. Iíve driven the trailer for thousands of miles and the tires have been fine. But I tow level, check the pressure, have a special pump for inflating them, and donít exceed 80mph in hot weather for long periods of time. My tow vehcile rear axel tires are rated at 2300lbs each at 50psi, and I keep them at 44psi with about 2000lbs on them.
JohnD10 is offline   Reply With Quote
flagstaff
