Old 08-21-2010, 06:02 PM   #1
Jamboree Player
12 volt system
I have an 2006 30" 5er ... is the 12 volt system supposed to give me some interior lighting? All I get is road lights and the tip out motor ..... There's a fuse (30amp) inline by the battery in the boot, where is the 12volt fuse panel hiding? ........ just got it and I'm pumped
tcalhoun777 is offline   Reply With Quote
Old 08-21-2010, 06:07 PM   #2
Arn
Arn
All interior lights should be 12v. Look near the floor, below the fridge etc. for your converter or inverter. That's where you'll find what should be a series of ATO type automotive fuses. Check them all out.
Arn is offline   Reply With Quote
Old 08-21-2010, 06:38 PM   #3
Jamboree Player
got it thanks for the quick reply ..... will I only get interior lights on shore power or from a genny?
Old 08-21-2010, 06:57 PM   #4
Arn
Arn
I've only ever seen interior lights from your battery, not shore power or a genny.
Old 08-21-2010, 09:25 PM   #5
NWJeeper's Avatar
Shore power and generator will power the converter/charger which does supply 12 volts to the entire system as well as for charging the batteries. The amount the converter puts out is dependant on how much load you are placing on the system and how much charge the batteries need at the time.
Ed & Wendy
www.nwjeepn.com
12 volt, rockwood
