Old 02-03-2013, 03:19 PM   #1
garry
12 volt wont work
Ok folks need your help. I went to test tow my Rockwwod 8280ws with my new to me Ford f250 (tows real nice by the way) I hooked up the battery and my landing gear worked. After i hooked up to truck the message trailer wiring fault and nothing worked no lights no landing gear nothing. I unhooked from the truck and still nothing. I hooked up battery charger and still nothing. I hooked up the trailer plug back to truck and all 12 volt came back on lights landing gear everything. So I disconnected the battery and all 12 volt still worked as long as plugged in to truck. I hooked up the 30 amp and everything 12 volt worked even with the battery disconnected. I went ahead with the test tow and when I got back left charger on battery for 2.0 hours still nothing on 12 volt unless truck or electric is hooked up. I have 2 fuses by the battery and checked both they are good. Took the inverter out and there are 3 fuses behind it and they are good I even check all the fuses in the inverter and they are good. Battery is only 2 years old could it be the battery or am I missing something. SAny help would be appreciated
Garry
Camperdad
1DW,1 DS,1DD,1 2 furry friends
2011 Rockwood 8280ws 5ver
2011 Ford F250 Lariet 6.2l 3.73gears
camperdad is offline   Reply With Quote
Old 02-03-2013, 03:24 PM   #2
Follow the battery line from the battery to the converter you may have a resettable breaker in line that has tripped. There will be a small button on the side to reset it.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 02-03-2013, 03:45 PM   #3
Owner/Operator
RodeoGeorge's Avatar
I'd follow the + wire from the battery and look for a disconnect switch, since everything works with TV power or Converter power.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
12 volt
