Old 05-30-2012, 10:03 AM   #1
1809S floor space
Can someone who has a Mini Lite 1809s close by measure the floor space indicated by the yellow below? I want to shop for an area rug (my TT is on order). Thanks!!
Elidh is offline   Reply With Quote
Old 05-30-2012, 10:32 PM   #2
F22
F22's Avatar
I don't have that measurement for you, as I have the 2109S, but here is something to keep in mind, if you did not know it -- If you have a rug in front of the sofa, when the slide out is out, when you slide it in, the sofa will be pushing the rug out of the way. So if you want to fill that area with a rug, you will need to fold it over out of the way when you bring the slide in.
We just use a 5' or 6' rug runner for the interior, so it can be moved over toward the kitchen in our 2109S when we move the slide in.
F22 is offline   Reply With Quote
Old 05-31-2012, 06:40 AM   #3
Thanks, F22. I had planned to fold the rug up before closing the slide.
Old 05-31-2012, 07:00 AM   #4
Like F22, we have the 2109S and are using a 10 ft. long runner that has been cut in half so most of the floor area between the kitchen and sofa is covered and we can just move the piece closest to the sofa over the other one. Bought the runner at Lowes for about $30.
NanaKaren
Karen Elling
2012 Rockwood Mini Lite 2109S
Useta have a 17 ft Casita LD twin bed mod &
Coleman pop up
NanaKaren is offline   Reply With Quote
Old 05-31-2012, 07:20 AM   #5
If I had just read this a few minutes ago I could have measured for you, however, we are ready to move so have everything closed up. Will check back later to see if anyone has been able to help you.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 05-31-2012, 07:24 AM   #6
Thanks Emptypockets - I'm finding ways to occupy/amuse myself until the 1809s arrives, and decorating the interior is a fun diversion!
Old 05-31-2012, 11:52 AM   #7
FreedomTracker's Avatar
Answer is 86" x 43".
Slide couch will not interfere b/c it has a skirt that hangs down in front and carpet will simply go under it with no physical obstructions.
P.S. We actually like not having a carpet down the aisle b/c it makes it easier to just sweep out the dirt... just purchased a small 18"x30" rubber backed carpet to go in front of the door... just shake it out when dirty. Paid $5.97 at WalMart.
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 05-31-2012, 01:14 PM   #8
Thanks, FreedomTracker - I appreciate it! That is a bigger area than I thought!
Old 06-01-2012, 09:53 AM   #9
Thanks Freedom Tracker X2
1809s
