19FBS stored, no power and Houston humidity
We store our 19FBS in a spot that has no shore power available. We live in Houston, TX. The average humidity here is almost 82% and soon it will be higher than that. Often. We have DampRids inside, they are drawing moisture. But I'm concerned they do not draw ENOUGH. I am using a humidity gauge to track how effective they are. They seem to have difficulty dropping the humidity inside significantly when it's hot; > 75 degrees, and when it's very humid; > 75%. For more than half the year Houston exceeds both those temps and levels of humidity. My understanding is it's best to keep it well below 60% inside. Any tips? The DampRids may work great in other less humid locations, but we have no plan on moving. LOL. Are there areas I need to look at where moisture entering can be minimized? Like under the bed by way of the passthrough maybe? ALSO, if you live in an area as humid as Houston, do you leave vents open or closed in humidity like this? I've seen arguments for both but right now ours are closed. Any suggestions would be greatly appreciated. TIA
