Old 06-24-2018, 02:34 PM   #1
1st trip disapointing.
Well pur first b.c trip in our new Geo Pro 19FD was a 1 1/2 hour drive.
Before left we started propane fridge, bled gad out through stove and grill to make sure no air in line. Turned fridge on and pushed gas button up. 3 hours fridge still hot. Got to camp hooked up electric switched gas off for fridge and was cold within a hour.
Propane prtion of tankless wouldnt lite, and hooking up to cable outside of trsiler delivered a horrid scratchy pic and stTic sound. Hooked cable direct from post to tv through door and was perfect pic and sound.. brand new tailer 2018.
ID:	177063   Click image for larger version
ID:	177064   Click image for larger version
ID:	177065   Click image for larger version
ID:	177066   Click image for larger version
ProAngler is offline   Reply With Quote
Old 06-24-2018, 02:38 PM   #2
Fridge takes a number of hours to cool down. Most of us start it the day before. Dealer should have told you this.
2011 Traverse LT, 3.6L, FWD
Old 06-24-2018, 02:47 PM   #3
mbcabinetmaker's Avatar
At least you caught some fish. ��
Mark
2019 Surveyor 201RBS
2017 Nissan Titan XD
mbcabinetmaker is offline   Reply With Quote
Old 06-24-2018, 02:49 PM   #4
rattleNsmoke's Avatar
Nice catch. You'll get the bugs worked out
rattleNsmoke is offline   Reply With Quote
Old 06-24-2018, 02:56 PM   #5
Not a newbie
Johnfort's Avatar
Nice fish, lake, steaks........
Sorry you got off to a bad start. Ditto on starting the fridge a day before. I leave mine on electric if the next trip is within a few weeks. I run all of the stuff for 2 or 3 days prior to reduce the disappointment level. I fill the tank and run the water, then drain and refill the morning I leave or the night before.
Did you hear the fridge light or see indicators that it was on?
What altitude were you at? Does the fridge and WH light at "home"?
Johnfort is online now   Reply With Quote
Old 06-24-2018, 03:36 PM   #6
Fridge just on power got cold fast. I dont think the propane was firing, just like wster heater propane nor firing.. brand new trailer cab look e pic horrid when hooked up to outside port, perfect when plugged directly into tv.
Old 06-24-2018, 03:56 PM   #7
I'm having a bit of difficulty reading what you typed but if hooking up and running everything at home is an option then I suggest working out all the bugs there. Test run all propane devices.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 06-24-2018, 04:02 PM   #8
Flybob's Avatar
Did you turn off the TV antenna amplifier ( small button on coax connector plate). If button in on position it will corrupt anything on the cable.
Did the stove work? If the propane lines were empty and you turned the propane on quickly, the free flow safety valve could have shut of the propane. To correct this, shut off propane, disconnect tank, wait a few minutes, then reconnect tank. Turn propane very slowly until you just hear some propane flow. Stop and wait for a minute until lines are pressurized. Turn on the propane completely.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-24-2018, 04:13 PM   #9
lswartz's Avatar
I do the same on my TT. there is still some air in the line to the refrigerator that you have to bleed out. It takes about 2-3 restarts on mine before I hear the flame 🔥 on the refrigerator light. Note that I did’t say the igniter which is trying to lite the propane.
If you have a doubt, take it apart until you can see the flame. I do this at the beginning of the year to get the powered rust out of the burner tube as a preventative measure.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 06-24-2018, 04:44 PM   #10
Stove and bbq outlet worked great.. what button? The one where the 12v plugs in for the tv?
