Old 05-26-2013, 03:35 PM   #1
2012 Mini Lite 2109S Roof Leak
Hey all,
Thought I would give everyone a heads up on a roof leak I found today. I went to do a mod (to be posted separately) and found water in the cabinet above the stove.
Bottom line is that water was tracking done the grey wire coming in from the roof. This turned out to be the tv antenna wire.
Repaired with Dicor.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 06-01-2013, 12:14 PM   #2
mkillora's Avatar
This seems to be a common and reoccuring problem with the 2109s. Ours is a 2012 as well and we had the same leak, coming from the same area, i.e. the antenae cable that goes thru the roof. Spoke to a number of other 2109s owners and they all experienced the same leak. The guy in charge of doing the caulking at the factory should take note!
mkillora is offline   Reply With Quote
