Old 05-30-2013, 07:59 AM   #11
VinceU's Avatar
Originally Posted by GearHd6
There is a sticker on the side of the camper that states what the fresh water tank weighs when full so I knew the weight. I just never expected the supports to be under-engineered to the point that you can't haul the full weight over the road. That's just poor designing. My parents Alpenlite 5th wheel has something like 100+ gallons of fresh water and they travel over the road with it.
It doesn't seem like it would have been difficult to use some 1/4" thick 2"x2" angle iron. I still think it might be vent tube related but I'll see what the dealer thinks. If they claim I can't haul with a full tank I think I'll be making up my own brackets.
Seems like you can haul food, water, or steel in your trailer, just not all at the same time. Pay close attention to your CCC rating. If you don't, you'll be changing axels next!
Old 05-30-2013, 10:00 AM   #12
jeepman71's Avatar
Not being able to haul a full load of water regardless of weight would be unacceptable. We spend time dry camping and if we don't haul it in we don't have it.
Our 8289WS had a bent support and Forrest River replaced it.
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline   Reply With Quote
Old 05-30-2013, 11:02 AM   #13
The same thing happened to my fresh water bracket. One of the campgrounds I go to you have to fill your fresh water tank and then cross a set of railroad tracks, I'm pretty sure that is when it first happened. I had it "repaired" under warranty and all the dealer did was bend the bar straight and then use blocks of wood on either side of the tank that lasted until the next time I filled the tank and didn't even have to cross tracks. Here is how I repaired mine. IM me and I will give you a description of exactly what I did.
electrician549 is offline   Reply With Quote
Old 05-31-2013, 10:52 AM   #14
ahh yes, electricians like unistrut. Good thinking!
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 06-03-2013, 02:12 PM   #15
I dropped it off at the dealer today for this and a couple other issues. We'll see how they handle it.
GearHd6 is offline   Reply With Quote
Old 06-06-2013, 08:36 PM   #16
Thanks, keep us posted. I plan to look at my brackets even though I have not traveled with any water in the tanks.
Old 06-14-2013, 12:09 PM   #17
mkillora's Avatar
Add me to the growing list with bent brackets! Decided to check mine out yesterday, even though I have never travelled with a full tank, and never suspected that mine would be bent. Lo and behold, two badly bent supports! The only time our tanks are completely full are when we are dry camping and it's just moving around in the campground. Surely this couldn't have caused this, but I suppose it must have. Another example of using sub-standard material on TT's.
mkillora is offline   Reply With Quote
Old 06-14-2013, 12:50 PM   #18
I'm sorry to hear yours are bent also. At this point I'm convinced it's the routing of the water tank vent line. It needs to stay up tight to the bottom of the camper but the way the factory routes it it has low points. The vent line then gets water trapped in it so then when you're filling the tank the air can't escape so it blows the tank up like a balloon. Then it bends the brackets like its done to yours and mine.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
Old 06-14-2013, 01:31 PM   #19
lswartz's Avatar
If a couple others are interested too, you might post your fix. Looks like others are going to need to make this modification.
I just got back from filling my fresh water tank up & air seems to escape OK. I'll be watching that too.
Thanks.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 06-15-2013, 10:06 AM   #20
mkillora's Avatar
I'm having a hard time thinking that it's the vent line that's causing the problems. If there was sufficient pressure to "blow the tank up like a balloon", I would think that that amount of pressure would blow out any water traps in the vent line first(?) But then again, I suppose anything is possible.
I'd also like to hear the details on how "Electrician" did the mod. My first thoughts on straightening the brackets out is to place hydraulic jacks underneath them and slowly apply pressure. My concern, however, is that with that amount of pressure, that the welds at either end of the brackets may break, causing even more of a mess.
Wondering whether Forest River is aware of this problem?
