Old 05-28-2013, 07:17 PM   #1
2109S Fresh Water Tank Brackets (Bent?)
I've got a 2013 Mini Lite 2109S that has been transported 50 miles so far with a full fresh water tank. Then today I went to fill the tank up for a trip this coming Thursday and I looked underneath to see this.
Front Bracket
Rear Bracket
Has anyone else every experienced this? It just seems like the side to side supports aren't thick enough and there aren't enough front to back supports.
GearHd6 is offline   Reply With Quote
Old 05-28-2013, 07:24 PM   #2
DDC
DDC's Avatar
Now I see why they enclose the under-belly, hides a lot.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-28-2013, 07:31 PM   #3
It's not enclosed, it's fully exposed to show the bent up mess. I don't have time to do much with it or get it to a dealer so I just drained the tank to half full then put a bottle jack under it to try and straighten it out some. The campground we're going to has full hookups so we should be fine. I just like to travel with fresh water just in case.
It's already going back to the dealer after this trip for a front window water leak. I guess we'll add this to the list. I'd love to know what their fix will be.
Old 05-28-2013, 08:43 PM   #4
VinceU's Avatar
I think FR will tell you never travel with full tanks.
Old 05-28-2013, 08:50 PM   #5
Really? You can't travel with 30 gallons of water? That seems like a poor design if that's the case. I'll see what they say. I think it's due to poor vent line routing.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
Old 05-28-2013, 09:06 PM   #6
Whether you can or not..."just in case" means you carry maybe 5 gallons. That's a lot of weight you're dragging around for nothing.
Old 05-28-2013, 09:20 PM   #7
Wow that's quite the let down. You'd think they'd have warnings somewhere not to travel with the tank full. We like to camp a lot at state parks with no hookups so this made things a little easier.
2013 Rockwood 2109S
Old 05-28-2013, 09:25 PM   #8
DDC
DDC's Avatar
I wonder if the truck makers could use that excuse to you no don't put fuel in the tank it might fall out.
Old 05-30-2013, 05:52 AM   #9
I have a 2012 2109S and we camp at state parks a lot that do not have hookups. They all have a dump station plus a potable water connection so that you can fill your water tank prior to setting up your camper.
A gallon of water weighs 8.34 lbs, so 30 gallons is ~250 lbs. Lot of weight to be carrying and bouncing around on the support brackets.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 05-30-2013, 07:13 AM   #10
There is a sticker on the side of the camper that states what the fresh water tank weighs when full so I knew the weight. I just never expected the supports to be under-engineered to the point that you can't haul the full weight over the road. That's just poor designing. My parents Alpenlite 5th wheel has something like 100+ gallons of fresh water and they travel over the road with it.
It doesn't seem like it would have been difficult to use some 1/4" thick 2"x2" angle iron. I still think it might be vent tube related but I'll see what the dealer thinks. If they claim I can't haul with a full tank I think I'll be making up my own brackets.
